06-01-2005, 19:14 | #4 (permalink) | |
Insane Poster Join Date: Dec 2004 Age: 43
Member: 100195 Status: Offline Thanks Meter: 75 | hi Quote:
new nokia all hardware solution searc 3200 led IC | |
06-04-2005, 22:14 | #8 (permalink) | |
No Life Poster Join Date: Jan 2005 Location: india Age: 49
Member: 107636 Status: Offline Thanks Meter: 100 | Quote:
step 1 : after u put on the phone are u able to switch it off with on/off switch or u have to switch it off by removingb the battery step 2 : if u r able to put the phone off with on/off switch then try to resolder the display connector also check the display connector lines as per the circuit diagram. step 3 : in case if u r not able to power off the phone with on/off switch then 100% software flash ur phone mcu + ppm parts. u should b ok | |
07-23-2005, 10:54 | #10 (permalink) |
No Life Poster Join Date: May 2004 Age: 54
Member: 66136 Status: Offline Thanks Meter: 200 | have same probleme, I test LCD of my 3200 on 3100, and LCde work perfectly, and I put LCd of my 3100 on 3200 = same probleme ? some one have idea or solution for this probleme. br, JAVA Good. |
12-05-2005, 10:36 | #11 (permalink) |
Junior Member Join Date: May 2005
Member: 149232 Status: Offline Thanks Meter: 1 | if your fone can call and recieve but no display remove the 2 resistors below the power switch(on either side of antenna pad) and link the track,it worked for me let me know if it helps any1 else |
Problem with old patchs for nokia, with nokia 3200 and 3220 v03.60 - dead phones!!! | DJiCE | Universalbox | 14 | 06-14-2007 15:18 |
Nokia 6610 or Nokia 3200 | GPRS | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 01-18-2004 10:41 |
Test with Nokia 3200 | Raskal | Twisterflasher | 16 | 01-02-2004 03:51 |
Unlock nokia 3200 | corachon | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 10-25-2003 00:16 |
