02-29-2004, 11:38 | #1 (permalink) |
Freak Poster Join Date: Jun 2003 Location: Pakistan Age: 43
Member: 31534 Status: Offline Thanks Meter: 3 | nokia 3210 signal problem I have Nokia 3210 which has a fault "Signals down after 10 seconds". I have checked the voltages at PA. The voltages are ok. I also rehot the cobba and ccont but the fault is same here. Now plz tell me what do i do? Thanks all of you. bye. |
02-29-2004, 12:21 | #2 (permalink) |
No Life Poster Join Date: Dec 2001 Location: United Arab Emirates, Dubai Age: 52
Member: 7751 Status: Offline Thanks Meter: 74 | @Shahrukh This can on the 3210 have a lot of causes ! On what network does it drop the dignal ? 900 or 1800 MHZ ? or does it only do it on one of the networks ? I would suggest that you change the PA on which network it drops it ! The "drop signal" is in my exsperince mostly either caused by PA or or the COBBA, the phone dont have any TX. Rehotting will rarely help on either COBBA or PA ! Always change components, since the rehotting in most cases will return the phone later with same fault. If you have cracked Wintesla you may hook it up and measure the RSSI value and post it here, it'll give a better idea whats wrong, or you may activate Netmonitor and study posts on this board on how to use it !! theres a lot of them. You can for a starter browse through this thread here Some information can be used from there. Also do a search fro Netmonitor on this board. Regards |
Nokia 3210.....Signal?? | AFR | Nokia Hardware & Hardware Repair | 6 | 12-21-2002 05:11 |
3210 signal problem | feverdj | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-23-2002 07:13 |
3210 signal problem | matoxx | Nokia Hardware & Hardware Repair | 4 | 06-21-2002 20:59 |
nokia 3210 signal | GsMen | Nokia Hardware & Hardware Repair | 3 | 11-04-2001 19:10 |
nokia 3210 signal coming and going | Blartiartfast | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 05-29-2001 23:57 |
