Old 10-30-2009, 09:31   #1 (permalink)
Member: 1122148
Thanks Meter: 35
nokia 3220 has network problem how to repair it
i have nokia 3220 it had network problem then i try to flash with hwk it was ok like for 1 hour but when i gave to customer he came after few minuts there was no network i check then try falsh it but no netwrk
so what could the probelm steel no network n this the info of the phone with HWK
MCU SW : V 04.94 30-06-05 RH-37 (c) Nokia.
PPM SW : V 04.94 30-06-05 RH-37 (c) Nokia. C
Prd.Code: 0518260
Bpr.Code: 0519858
Prod.Sn : MRB431288
HW Vers : 5053
UEM : 400
UPP : 8514 [2142]
RFIC Ver: 0205
DSP Vers: B0435U_05w08
LCD Type: AMAZON
IMEI : 357623-00-888619-2
SL Conf : 001-01-00000000000
SL Prof : 000000000000000-2
SL Var : 00553576230088861900
SL Aux : 00025555
HW Sig : 3859F97AB64B250F
Box Id : 894F561B14F28D9D
BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
MastCode: 25 13 07 75 42
Provider: GSM Test Equipment
#pw+ 159 504 372 737 517 +1#
#pw+ 485 397 401 305 702 +2#
#pw+ 152 394 074 035 101 +3#
#pw+ 487 837 301 540 544 +4#
#pw+ 008 013 326 662 527 +5#
#pw+ 339 856 053 730 463 +6#
#pw+ 414 227 736 244 030 +7#
but there diffrent in Pro.code phone has 517300 n here is diffrent
soultion pls
Old 10-30-2009, 15:00   #2 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,378
Prd.Code: 0518260
Bpr.Code: 0519858
Prod.Sn : MRB431288
HW Vers : 5053
UEM : 400
UPP : 8514 [2142]
RFIC Ver: 0205
LCD Type: AMAZON
SL Aux : 00025555
soultion pls
Bro.try this solution.
result post here.
Old 10-30-2009, 15:36   #3 (permalink)
baldev's Avatar
Member: 153805
Thanks Meter: 324
Near on off switch under cover is oscillator.open cover by carefully cutting metal shield.clean it and dry with mild heat.also check manually searching network.
Nokia 5220 RM410 in contact service how to repair it? ..::Fixcell::.. Universalbox 4 02-02-2010 12:26
3650 has no PM, How to repair it 123567890 WD2 & APE (Symbian Phones) 15 04-17-2008 00:16
T191 dead after flashing. how to repair it? phonesoft Motorola ODM 2 01-29-2003 17:04
T191 dead, rest in peace how to repair it? indel306 Motorola ODM 10 07-04-2002 08:22
8210 no network - How to repair it ? unlockphone Nokia Hardware & Hardware Repair 14 07-15-2001 00:17
Page generated in 0.25790 seconds with 8 queries
