09-27-2008, 12:23 | #1 (permalink) |
Freak Poster Join Date: May 2006
Member: 283474 Status: Offline Thanks Meter: 41 | nokia 3230 running down battery |
09-28-2008, 17:18 | #2 (permalink) | |
Freak Poster Join Date: Jun 2008 Location: Heaven
Member: 801083 Status: Offline Thanks Meter: 99 | Quote:
If not work 1. Full flash 2. Write pm 3. Format user area 4. Ui setting Or only write pm than ui setting | |
The Following User Says Thank You to AdickAsia For This Useful Post: |
09-28-2008, 17:54 | #3 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | for triping on&off it's like software problem so full flash the phone as already posted by adickasia if same after full flash reball flash ic only , and for battery drain fast means phone consume bat power very fast so check PA |
The Following User Says Thank You to .:SARCAR:. For This Useful Post: |
09-30-2008, 11:06 | #5 (permalink) |
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | friend first check the phone with working lcd of 3230 if same check or resold lcd connector , if same check or replace whole ui board if again same fault of display then go through hardware portion means reball or change lcd esd filters , post result |
nokia 3310 battery running down fast | gbada | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 15 | 03-20-2017 20:02 |
nokia 3230 droped down | sandeepmobiles | Nokia Base Band 5 ( BB-5 ) | 0 | 02-28-2010 13:21 |
nokia 1100 running down battrie fast | de brain box | Nokia Hardware & Hardware Repair | 12 | 09-22-2007 20:15 |
mt11o battery quick run down | okiki | Mitsubishi | 0 | 03-06-2005 22:31 |
Nokia 3310 Battery runs down | YamahaR1 | Nokia Hardware & Hardware Repair | 2 | 09-11-2002 18:36 |
