Old 10-16-2008, 18:54   #1 (permalink)
Member: 877563
Thanks Meter: 14
Exclamation Nokia-3230 short cercuit
Respected members,
nokia 3230 bord short, what i do. Please help me.
Old 10-16-2008, 19:01   #2 (permalink)
Member: 856796
Thanks Meter: 40
1.clean very well,,
2.reheat a bit,,
3.remove p.a.,,
if still shorted,,,then try other parts,,
Old 10-16-2008, 19:05   #3 (permalink)
Member: 11726
Thanks Meter: 10
hi
don't remove the PA just remove the power supply coil & check the short
Old 10-16-2008, 20:13   #4 (permalink)
Member: 856796
Thanks Meter: 40
Originally Posted by fantom View Post
hi
looking for shorted component on board is only by chance,,your chances are good if you examine the board carefully,,for the board which become shorted thru normal use(that means not misused,,water,dropped or anything)most common is p.a.,,power ic and charging ic,,
for water damaged boards,,most common are ic's that give high voltage output,,smps,,back ligth ic, and ofcourse power ic,,and charging ic,,,and the ones that has corrotions,,,so visual checking is needed,,,
COILS are always shorted,,if it is open it is not working so it is badddddd,,
Old 10-16-2008, 20:22   #5 (permalink)
Member: 11726
Thanks Meter: 10
i ment remove the coil that supply the pa with voltage to avoid distroying the pa with heat if its not shorted then he can check the short at battery pins if the short is gone then he will be sure that the pa is shorted & if the short at battery pins still this mean its not the PA ok Mr bearhug
The Following User Says Thank You to fantom For This Useful Post:
nokia 3230 nokia nokia restart pro so i have the set with jaf but it shows this error lavkey Nokia Hardware & Hardware Repair 1 10-06-2008 14:14
nokia 3230 & nokia bluetooth BH-200 problem raz002 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 12-26-2006 13:17
Service Manual for Nokia 3230 and Nokia 8800 janar_jk Nokia Digital Core Technology 4 ( DCT-4 ) 10 01-03-2006 16:07
nokia pc suite 6.5 and nokia 3230 Koponen Nokia Multimedia 16 09-01-2005 11:06
Nokia 3230,Can't Link With Nokia PC Suite 6.5 ranga Nokia Multimedia 1 04-15-2005 18:05
Page generated in 0.14491 seconds with 10 queries
