03-31-2007, 20:02 | #1 (permalink) |
Freak Poster Join Date: Jan 2006
Member: 217853 Status: Offline Thanks Meter: 13 | Nokia 3230 White Display Only Rest Is Ok Ic And Rehot Coneecter But No Result Rest Is Ok.means Mobile Is Working Other Functions Normally. |
03-31-2007, 21:21 | #2 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In a point from Universe! Age: 40
Member: 235325 Status: Offline Sonork: 100.1593552 Thanks Meter: 523 | Hi, Try,using a schematic diagram,to locate the lcd driver and replace it.Also the white lcd problem can apear if CPU have malfounction or flatcable is damaged.Good Luck! |
04-01-2007, 20:33 | #6 (permalink) |
Member: 217853 Status: Offline Thanks Meter: 13 | i already told u i done all things but no result .it is the problem of cpu but the cpu is glued .now what i do, i am from srinagar here is no option of removing glued ic.thanx to all of u for writting good suggestions . |
nokia 3230 white display | Gautam Mhz | Nokia Hardware & Hardware Repair | 3 | 09-12-2009 09:31 |
Nokia 3230 White Light Only | Ankit Verma | WD2 & APE (Symbian Phones) | 1 | 08-01-2008 08:30 |
nokia 3230 white display | cellsolutions1 | Nokia Hardware & Hardware Repair | 7 | 07-04-2008 22:49 |
3230 white display only plz help | amanhalwara | Nokia Hardware & Hardware Repair | 16 | 04-21-2008 12:41 |
X820 after remove msl now set is in white display on off is ok..00000000000000 | makkah mobile | Samsung Flashers, Software, Firmware. | 0 | 03-30-2007 08:56 |
