11-14-2008, 19:39 | #4 (permalink) |
Freak Poster Join Date: Sep 2006 Location: punjab
Member: 357914 Status: Offline Thanks Meter: 71 | this is moslty problem of flex cable so please check first flex board, and also check the ok lcd and u can make or receive calls? |
The Following User Says Thank You to amardeepsahi For This Useful Post: |
11-15-2008, 05:10 | #7 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Bareilly(U.P) Age: 50
Member: 405715 Status: Offline Thanks Meter: 271 | Quote:
2-if white light hang then remove marked ic and short two points shown in picture.if same 3-erase flash an reflash with latest firmware again. 4-write full pm and do full factory reset. WBR shoeb | |
The Following 4 Users Say Thank You to shuaib_kashish For This Useful Post: |
11-15-2008, 05:20 | #8 (permalink) |
Member: 405715 Status: Offline Thanks Meter: 271 | 3230 hangs on 'NOKIA' 1-format user area 2-change boot ic shown in picture |
The Following 2 Users Say Thank You to shuaib_kashish For This Useful Post: |
11-15-2008, 21:34 | #9 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Faisalabad pakistan
Member: 900083 Status: Offline Thanks Meter: 601 | 3230 white display Brother first u check lcd if ok so change your front complete panel with fps (strip) and that is a last solution your prob will b solved |
nokia 1202 White Disply (Urgentttt) | ashish532 | Nokia Hardware & Hardware Repair | 5 | 03-18-2010 15:07 |
Nokia 3230 white disply | frfaisal | Nokia Hardware & Hardware Repair | 2 | 11-15-2008 18:46 |
Nokia 3230 White Screen | bonnyk1 | Nokia Hardware & Hardware Repair | 1 | 07-25-2007 08:39 |
Nokia 3230 White Display Only Rest Is Ok | rajus | Nokia Hardware & Hardware Repair | 5 | 04-01-2007 20:33 |
Nokia 7820 White Disply | Gsm Lab | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 08-03-2005 11:35 |
