Old 01-24-2005, 17:06   #1 (permalink)
Member: 65774
Thanks Meter: 4
Red face nokia 3310
Nokia 3310 when u power it on it comes on after pressing for several times and even when it powers on still it drops network after light has gone off,please any one there assist me.
Old 01-24-2005, 17:19   #2 (permalink)
Member: 105049
Depends on if the phone has has water damage if no water damage replace PA and all should be fine.
CHEERS
wagsm
Old 02-05-2005, 22:28   #3 (permalink)
Unggul's Avatar
Member: 71273
Thanks Meter: 14
if still comes, reball the power ic (CCONT)
Old 02-05-2005, 23:58   #4 (permalink)
Member: 67780
Thanks Meter: 2
Try the search buton and you will find old post's with the answer for your problem.
Old 02-06-2005, 15:56   #5 (permalink)
Member: 81153
check continuity between pa and vbatt
Hello friend,
Check for continuity between vbatt and pa, solved many network problems with this method.
There should be continuity between vbatt abd pin 4 and 6 of pa.
Best of luck!
regards,
Raja3333
Old 02-06-2005, 16:16   #6 (permalink)
bestman's Avatar
Member: 61294
Thanks Meter: 49
always try or check old post on nokia phone, related problems .
for your phone , problem ... try another battery on your phone ...
bestman
Old 02-06-2005, 16:46   #7 (permalink)
Member: 36906
Hello guy,I need advice on how to reball successfully.I have all the needed tools,yet I do not know the noozle to use,the voltage of heat to apply,and how close the heat should be to the ic.
Thanks.
Old 02-07-2005, 00:50   #8 (permalink)
Unggul's Avatar
Member: 71273
Thanks Meter: 14
Thanks.
use a hotair (****er) and BGA tool with low air 1-2 bars and the heater is about 300-400 bars (i'm using Quick and Gordak hotair) but with other type i don't know how the heat and the air, you shold heating it about 5-7 cm on the ic's (not too close).
Unggul
Is it the on/off switch is same in between nokia 6600 and nokia 3310 yccomc Nokia Hardware & Hardware Repair 2 09-30-2005 03:33
Wanted x1 nokia 3310 board & x1 nokia 3410 board cameraman Wanted Products 4 09-12-2004 16:11
NOKIA 3310 AMTX99 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 03-26-2001 17:01
There it is ! The new Nokia 3310 Tevoxx Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-01-2000 13:44
NOKIA 3310 Tevoxx Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 08-31-2000 14:05
Page generated in 0.22241 seconds with 10 queries
