05-16-2002, 00:09 | #1 (permalink) |
No Life Poster Join Date: Nov 2001 Location: Slovakia
Member: 7586 Status: Offline Thanks Meter: 11 | Nokia 3310, don't power on after replacing PA I replaced PA on N3310, old one was broken. Now phone don't power on. Where should be the problem ?? Don't start charger. Then i've tried to remove PA, but problem remains. I dunno if phone without PA can power on .. Any idea please? b.r. Pali |
05-16-2002, 21:21 | #5 (permalink) |
Member: 7586 Status: Offline Thanks Meter: 11 | ok, now i know that phone can power on without PA. But my phone don't want to power on . Where should be problem now ? Phone was working before replacing PA. I just replace PA. b.r. Pali |
05-18-2002, 00:25 | #10 (permalink) |
Member: 7586 Status: Offline Thanks Meter: 11 | @Hanukkah i replaced the PA, phone can't power on. @all I checked , all resistor are on their right places. what now ? any idea how to fix this crazy problem ? b.r. Pali |
05-26-2002, 04:30 | #11 (permalink) |
Freak Poster Join Date: Dec 2001 Location: Earth
Member: 7934 Status: Offline Thanks Meter: 0 | Hi, Ohh Pali as all times you go so quickly You should to go step by step. You have told that your phone is working before replacing PA. So there's 3 points to verify them: 1- Your PA is damaged and it makes your phone out of work. 2- Your PA is good and you have done a mistake when you have soldred it. 3- Your phone is dead with out any relation with the PA. Firstly tell me why you have decided to replace your PA ? because may be it's not a PA problem. Secondly : have you verify mecanical problems ( bad contac, bad connector, swhitch on/off ) Does flasher reconize your phone ? Mail me PALI, with all description or your ICQ to give me more info, than we will pose the result here. Good luck : D |
05-28-2002, 18:34 | #15 (permalink) |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | own u try to tell us that u have ossiliscope u have change ur pa with a bad quility one just try another one 1-try to open the set when u don't fix the pa u must have working phone with a full par signal and droped suddnly 2- if it o.k fix the new pa if not change the antenna switch and try again if u got full signal complete the process.. 3- try to test the direction of all capisitors around the pa and compare it with working pcb... |
NOKIA e65 don't power on after flach !!!!! | seddik-gsm | Nokia Base Band 5 ( BB-5 ) | 4 | 06-11-2009 21:15 |
x640 don't power on after mobile info | alemil | SYSOL Platform | 4 | 10-15-2005 14:53 |
3310 don't power on | tanucu04 | Nokia Hardware & Hardware Repair | 11 | 09-14-2004 20:34 |
Motorola M3888 don't power on after flashing :( | s.Mobi | Motorola Old Legacy (EMMI) | 3 | 03-15-2002 01:58 |
Nokia 3310 not power on after water | snk | Nokia Hardware & Hardware Repair | 1 | 07-07-2001 16:15 |
