08-30-2007, 13:29 | #6 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: INDIA
Member: 350571 Status: Offline Thanks Meter: 920 | Quote:
dont try all above members solutions is wrong try my solution, first change good battery if battry ok means change power supply ic ( ccont ic ) ur problem solve 10000000% i made it many sets | |
08-30-2007, 18:47 | #9 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | for this kind of fault you should check four parts 1.battery 2.battery connector 3.PA 4.ccont change this parts step by step (1 >>>)so you can eaisly find faulty part , but first clean the pcb in u/s cleaner post result |
08-31-2007, 05:38 | #12 (permalink) |
Member: 350571 Status: Offline Thanks Meter: 920 | i am seeing here many .............................members hello give tested and good solution. without tested solutions all members writen like tested one good one ur problem solve ext. all above members are telling this problem in pf and pa ic problem this is not right solution. because battery charging and when we making call that time standby is generating power suply ic only not a pa ic if pa ic problem means board will be heat. i have 6years experience in service field and i am a good service teacher also all above posted members contact me pravate msg i will give my msn then we will disscuss wich solution is right, any one can ready to discuss with me about my solution ? hi all members if u have real experience knowladge then give solution otherwise get knowladge from others. this is 100% battery or power suply ic problem check battery if battery is ok then change power supply ic |
08-31-2007, 06:27 | #13 (permalink) |
Freak Poster Join Date: Aug 2007
Member: 572808 Status: Offline Thanks Meter: 607 | No Pa/pf Change Use Original Battery Connector Nokia 2100 And Sold Bsi Point On Pcb Ur Problem Is Solved 100% I Also Change Pa/pf But Soslution Plz Use My Idea This Is Very Simple And Sure100 % |
08-31-2007, 06:53 | #14 (permalink) |
Registered User Join Date: Aug 2007 Location: bohol philippines Age: 42
Member: 572549 Status: Offline Thanks Meter: 175 | try check first if shorted remove capacitor above left side of the ccont or power ic, if problem persist change PA. enjoy i already done it many times. check first all the connection. thanks |
nokia 3230 low battery always. 1.2v on batt connt ...plzz help | raggudada | Nokia Hardware & Hardware Repair | 4 | 01-29-2010 14:14 |
nokia 6070 dead batt low problem | dan21 | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 04-23-2007 07:23 |
Low batt with Nokia 3310 | micka22 | Nokia Hardware & Hardware Repair | 13 | 05-30-2004 07:08 |
3310 low batt | thecult | Nokia Hardware & Hardware Repair | 19 | 06-17-2003 01:37 |
Allway low batt on 2618s | Jeroen | Old Ericsson Phones & Sony Phones | 1 | 05-26-2001 21:21 |
