Old 04-09-2003, 16:41   #1 (permalink)
Member: 25763
Thanks Meter: 18
Nokia 3310 not switching on even after flashing
Hi
I have a Nokia 3310 dead phone. After flashing software also the handset does not switches on. Somebody please give the solution urgently and in detail please as I have many handsets with same problem and I am sure there may be lot of other Forum Members wanting this solution.
Rgds
supremegsm
Old 04-09-2003, 16:57   #2 (permalink)
GazI's Avatar
Member: 20566
Thanks Meter: 21
hi
Write MCU+PPM+ vigin eeprom
Old 04-09-2003, 17:04   #3 (permalink)
Member: 22526
Hi!
Try another full flash!
If still not switching on, check the phone type, because you flash 3330 with 3310 softwear........
Old 04-11-2003, 07:22   #4 (permalink)
Member: 25763
Thanks Meter: 18
Hi
I have flashed mcu+ppm+eep correct file for Nokia 3310 handset. I am sure its a hardware problem . Pls advise.
Rgds
supremegsm
Old 04-12-2003, 13:03   #5 (permalink)
Neo777's Avatar
Member: 11493
man ..
if it's a hardware problem .. why you flashing that phone ???
check a Service Manual level3 ..
and verify from Power Switch (S419) .. to MAD ..
is not so easy .. your problem !
Old 04-12-2003, 15:47   #6 (permalink)
Member: 25763
Thanks Meter: 18
Thanks NEO for your reply.
Could you please help me with circuit diagram for checking S419 to MAD IC.
Old 04-14-2003, 11:31   #7 (permalink)
vule's Avatar
Member: 10854
Sonork: 1578988
Thanks Meter: 3
Hiya
If power switch is damaged then You can not flash phone
If You can flash it, it means that hagar, 26Mhz, cpu, ram and flash are ok ( cpu boots normally ) !!! Anyway, when You do full flash, read full flash again and compare with one You flash in phone...If there is any difference then flash is damaged...
Otherwise, check/change ccont, 32768kHz osc B200, current consumption...
Vule
Old 04-14-2003, 13:47   #8 (permalink)
Member: 14004
Thanks Meter: 6
Very good reply from vule!
Old 04-14-2003, 14:36   #9 (permalink)
Syed's Avatar
Member: 19979
Thanks Meter: 115
the solution is simple and tested by me several times .... the flash IC is bad change it and flash the phone again and u will have a working phone.... another way to confirm is that u will not be able to read the flash correctly ad there will be errors.......
Old 04-14-2003, 15:21   #10 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 268
run wintesla to find where is the problem.phone is charging?
Old 04-14-2003, 16:10   #11 (permalink)
vule's Avatar
Member: 10854
Sonork: 1578988
Thanks Meter: 3
How to use wintesla when phone not power up???? :-)
Vule
Old 04-14-2003, 19:46   #12 (permalink)
ssatcom's Avatar
Member: 17098
Thanks Meter: 51
@syed
Very good reply
user code can not be removed even after flashing sunny_gsm Nokia Base Band 5 ( BB-5 ) 7 12-13-2008 21:25
3310 no switch on, but can flash cjohnjohn Nokia Hardware & Hardware Repair 2 08-07-2007 09:17
nokia 3410 not switching on nellabe Nokia Hardware & Hardware Repair 1 06-04-2007 11:32
Nokia 6630 not switching on not charging help edongzkisiete Nokia Base Band 5 ( BB-5 ) 0 01-05-2007 10:17
Nokia 3310 not power on after water snk Nokia Hardware & Hardware Repair 1 07-07-2001 17:15
Page generated in 0.36340 seconds with 8 queries
