Old 02-08-2005, 10:28   #1 (permalink)
Member: 84648
Thanks Meter: 3
nokia 3310 problem imei =0000000000
hello
please, i can not change imei number in nokia 3310 , because imei=00000000
any idea
best regards
Old 02-08-2005, 10:30   #2 (permalink)
.::Gsmdenis::.'s Avatar
Member: 79315
Thanks Meter: 6,024
pls use griffin solve this problem, try to got a new rpl file and flasher the phone ,at last ,don't forgot unlock! only a advise ,pls try run ,maybe will ok!
Old 02-08-2005, 10:34   #3 (permalink)
JulesJ's Avatar
Member: 104528
Thanks Meter: 3
Nokia 3310 does not have UEM and does not require rpl!!!!!!!
Change flash/eeprom ic with another rewrite iemi number using rolis 1.8 and set faid.reset all locks and full factory...Should work 1000000%
Old 02-08-2005, 10:38   #4 (permalink)
Member: 79315
Thanks Meter: 6,024
Iemi file is a rpl file, don't change that before, pls write a new IEMI no. for test if ok!
Old 02-08-2005, 10:56   #5 (permalink)
Member: 11886
denis_dd 3310 is not DCT4 you don't need to make rpl file, only use simple rolis or knock.
Old 02-08-2005, 11:07   #6 (permalink)
Member: 79315
Thanks Meter: 6,024
i know that ,I am only a range to be wide, the meaning not misled!
Old 02-08-2005, 22:11   #7 (permalink)
Unggul's Avatar
Member: 71273
Thanks Meter: 14
Originally Posted by eng.hamdow
hello
any idea
best regards
There was 75% software problem Reflash it with the same version !!!, because IMEI and data in 3310/82xx protected in Flash IC. if your phone data and IMEI was lost, the phone will shown CONTACT SERVICE, so you need to refresh the data within upgrade the new data. so you need to reflash with the same version, in Nokia phones (DCT 3) if IMEI=0000000 and you reflash the phone with other version, the phone still shown CS.
Unggul
Old 02-08-2005, 22:50   #8 (permalink)
Member: 84648
Thanks Meter: 3
thanks for alllllllllllllllllllllll
Old 02-08-2005, 23:32   #9 (permalink)
Member: 90171
After fullflash don't forget about change original Imei, and recalculate checksums ... 100% tested
Old 02-09-2005, 00:25   #10 (permalink)
Bypx's Avatar
Member: 62336
Thanks Meter: 115
UEM, RPL.. WTF???
BTW: Just write fubu, write imei e product code with knok, reset phone and unlock.
Good luck
Old 02-09-2005, 19:31   #11 (permalink)
Member: 104866
pls after flashing u discover u have corrupt imei pls kinndly use jordick to change the imei
Old 02-11-2005, 15:07   #12 (permalink)
Member: 93788
read full flash from working ph.write fls file 2 ph using knok18 or rolis flasher.after writing full flash,use rolis 1.8 to change imei back 2 original.clear sp locks,update faid and full factory reset.tested on 1000000 of handset.working thanks.
3310 with imei 0000000000 HOW TO Correct??? Eagle7 n-Box 6 05-10-2006 05:43
nokia 3310 problem karamusa Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-15-2002 14:25
Nokia 3310 problems..plz help! Tronic Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 12-03-2001 14:23
Nokia 3310 Problems - Turns Off By It Self TheEckoMan Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 08-14-2001 10:19
Nokia 3310 Problem IrdetoMaster Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 07-08-2001 15:54
Page generated in 0.22346 seconds with 9 queries
