08-11-2004, 20:30 | #1 (permalink) |
Junior Member Join Date: Aug 2004 Age: 60
Member: 77357 Status: Offline Thanks Meter: 0 | Nokia 3310 restarting When the SIM card is inserted its gets to the handshaking screen then restarts and continues to restart till you turn it off. Ive search through the this forum and it doesnt seem a common problem. Anyone have any ideas?? Thanks |
08-15-2004, 05:16 | #3 (permalink) |
No Life Poster Join Date: Apr 2004 Age: 49
Member: 61294 Status: Offline Thanks Meter: 49 | your need a new battery for your phone. and re -write the software of your phone . you can do this , by checking your phone software version , before next stage of operation. bestman. Last edited by bestman; 08-15-2004 at 05:52. |
08-17-2004, 19:18 | #5 (permalink) | |
Freak Poster Join Date: Oct 2002 Age: 55
Member: 16430 Status: Offline Thanks Meter: 2 | Quote:
If above dont help,times to replace/ball flash ic. Goodluck,hope these can solve your problems | |
08-18-2004, 09:37 | #7 (permalink) |
Freak Poster Join Date: Sep 2003 Location: Czech Rep. Age: 43
Member: 40423 Status: Offline Thanks Meter: 5 | No. restarting is not problem of PA i think. (when bat is ok.) 2 reasons >> Eeprom damaged ?? > reflash, update FAID, FF reset, (rehot FLASH IC Cobba fault ??> restarting phone and/or SIM NOT ACCEPTED, INVALID SIM, than rehot / change COBBA IC, Reflash, recalculate..... |
08-19-2004, 08:32 | #8 (permalink) |
No Life Poster Join Date: Dec 2002 Location: nigeria
Member: 18926 Status: Offline Sonork: ndagi Thanks Meter: 52 | @ vurugua phone restarting is definately hardware promlem.you need to interchange two resistors on pcb.i don't have pic so u gone have to do with me description.bottom left corner of pcb whe charging ic is, theres this doube resistor in between charging ic (on right side of charging) and a big capacitor, u need to care fully remove this resistor and replace it with identical resistor just a few milimiters above it and bring the one u remove there back down here.ti's a tricky move but trust me 100000000% working.tested at least 12 pphones. goodluck |
08-19-2004, 10:53 | #10 (permalink) |
Junior Member Join Date: Jul 2002 Location: Prague,Czech rep. Age: 48
Member: 13412 Status: Offline Thanks Meter: 0 | 1) 3310 Intermittent reboots or turns off: Remove L511 2) 3310 Phone switches off by itself: Solution 1: Without SIM stays on but with SIM it shuts off as it finds network: Use Rolis tool 1.8 "Reset Software" Solution 2: Without SIM stays on but with SIM it shuts off as it finds network: Change PA Solution 3: Check/replace battery contacts and PCB connection to battery contacts Solution 4: Switches off randomly, Remove L511, Solution 5: Switches off randomly,Change R301 From 2 x 2k2 to 2 x 100R R301 change has been done in production since following HWIDs: UP4IV (0201741) 0813 UD4 (0201476) 0814 UG4 (0201677) 0815 |
08-19-2004, 19:56 | #12 (permalink) | |
Member: 61294 Status: Offline Thanks Meter: 49 | Quote:
try using power supply unit for phone test run and booting techinques . try this, if you can ,sent me an mail for further explianation. bestman. | |
Nokia 3310 restarts | Abdul_Majeed | Nokia Hardware & Hardware Repair | 0 | 07-18-2009 21:31 |
nokia 3310 hang and restart when power on | barthosyn | Nokia Hardware & Hardware Repair | 12 | 01-05-2006 22:48 |
Nokia 3310 Restart Problem.!!!!!!!!! | ahtun | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 09-06-2004 09:39 |
Nokia 3310 Reception and Restart | tootsie | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 12 | 11-10-2003 12:47 |
3310 restart automatic | Gladiator | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 08-08-2001 07:52 |
