Old 10-15-2004, 17:40   #1 (permalink)
Member: 35518
Thanks Meter: 6
nokia 3315 not charging
Hi, i have nokia 3315 is not charging when insert battery there comes only battery symbol in off mode but when i switch on the phone there comes battery charging symbol after that phone gets on normally after few second there comes not charging on dislpay permanently pl help i have changed chaps tried reconnct charger jumper changed c216, c215 replased r22,v201,l202 and fuse but not solved
Old 10-16-2004, 08:23   #2 (permalink)
Cat10's Avatar
Member: 42123
Thanks Meter: 2
Check the resistance between charger pad and gnd if 0 ohm ( normal 50 kohm ) replace C217.
Old 10-17-2004, 19:18   #3 (permalink)
Member: 35518
Thanks Meter: 6
Thanks sir ,
problem solved by changing ccont now ok. thanks for reply
The Following 2 Users Say Thank You to param_commu For This Useful Post:
Old 07-02-2007, 06:04   #4 (permalink)
Member: 533962
Thanks Meter: 3
hallo sir i have 3315 charging problem my proble is charging voltage ok but charging not show always pls reply me
The Following 2 Users Say Thank You to mohit9450108319 For This Useful Post:
Old 07-10-2011, 08:49   #5 (permalink)
Member: 1459857
Sonork: anand_bijay
Originally Posted by param_commu View Post
Thanks sir ,
3315 not charging show & battery symbol is blinking.
nokia e60 not charging bluetoth not work kikoman Nokia Base Band 5 ( BB-5 ) 0 05-14-2007 22:59
3310/3315 not charging bbbbbb Nokia Hardware & Hardware Repair 1 11-22-2003 01:54
Nokia 3315 not detected by any software raj_mathurca Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-23-2003 03:40
NOKIA 5110 not charging liviu.m Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 05-26-2002 22:41
Nokia 3210 Not Charging Bemsas Nokia Hardware & Hardware Repair 1 11-03-2001 20:04
Page generated in 0.14335 seconds with 9 queries
