01-17-2004, 15:24 | #1 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Netherlands Age: 69
Member: 16473 Status: Offline Thanks Meter: 13 | Nokia 3330 signal drops to zero I have upgraded MCU + LP with latest version, but not good yet. Who can help me with this. BR, Jean Fleur |
01-18-2004, 13:09 | #5 (permalink) |
No Life Poster Join Date: Sep 2003 Age: 66
Member: 39601 Status: Offline Thanks Meter: 13 | If it is not emmeting any signal out ( use lighet sticker ) it could be PA. But if it gives signal out each 15-20 sec. for a coupple times it may be cobba , some times just reflow is enoughf. Good luck Br |
02-14-2004, 22:21 | #7 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Radiometer Medical ApSBrønshøj Age: 51
Member: 10854 Status: Offline Sonork: 1578988 Thanks Meter: 3 | It means that phone doesn't have TX and there is severe reasons for that... First, check software faults ( bad flash, eeprom and faid/imei calculation )... After it, try to get tx with wintesla ( testing/rf controls/tx and set power level to 5 ) and try to calibrate tx power level... If still no tx, check power supply to PA, PA itself, antenna switch, TXIQ signal, TXDET, cobba, hagar... BR Vule |
02-15-2004, 14:20 | #9 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Everywere Age: 46
Member: 18057 Status: Offline Thanks Meter: 64 | first make sure your receving area is ok, then go on wintesla service soft or set factory defalut. then go in rolis 1.9 .on the net moniter option. then check it. same position then first put COBBA ic. then check it . not sure then pull HAGAR then clean then fit it.. i think prob.......... 1000% solve for me everytime. NOTE: if any call attche then YOUR PF IS WORKING 10000% OK. nobody bit my this conformation. so not need to change pf.. in net come or go down or up it self. this is perfect tip to repair any 33xx or 82xx but sometimes CCONT also REASON . so u also check it , b.r. akki |
nokia 7610 signal drop plz help | graceful2 | Nokia Hardware & Hardware Repair | 2 | 03-03-2009 14:45 |
Nokia 6030 Signal drop and power off after few second | Munir Memon | Universalbox | 3 | 07-21-2008 11:42 |
nokia 3330 doesnt wnt to open | ren207 | Nokia Hardware & Hardware Repair | 1 | 05-10-2006 14:30 |
Nokia 6610 signal drop | .:::Dr. Cell:::. | Nokia Hardware & Hardware Repair | 9 | 01-15-2005 17:51 |
Nokia 7210. Signal Drop.. Water Damage?? | DrMobile | Nokia Hardware & Hardware Repair | 5 | 09-02-2004 08:17 |
