Old 04-23-2003, 21:37   #1 (permalink)
Jani-Jan's Avatar
Member: 19737
Thanks Meter: 133
.: Nokia 3360 No ring no vibra :.
hi
can any ony place here a solution for nokia 3360
ringer and vibra solution
Moved to Nokia H.R. for post wrong section.
Old 04-24-2003, 18:52   #2 (permalink)
Member: 1060
Thanks Meter: 10
Jani-Jan
did you check VB to ring and Virba connector pad ?
if it is ok, then UI or MAD got problem
Willy
Old 04-24-2003, 23:28   #3 (permalink)
Member: 19812
flash it , i´m it will work ok
Old 04-24-2003, 23:29   #4 (permalink)
Member: 19812
flash it i´m sure it will work fine
Old 05-21-2003, 11:02   #5 (permalink)
Member: 26606
Thanks Meter: 6
andorrani
do u have flash file for 3360 if u have then plz send me it
i have alot of need of it
and also told me that which dongle for flashing the fone if i am using the crack ver of phoenix or wintesla
thanks in advance
Old 05-21-2003, 11:52   #6 (permalink)
DrMobile's Avatar
Member: 5932
Thanks Meter: 1,694
@sagarka,
Its true flashing can solve NO RING/VIBRA problem in NOKIA 3360.
But U can't flash your 3360 with cracked phoniex even with wintesla becuase wintesla don't support 3360.
3360 is a DCT4 phone. and I can flash it Using Neelix II or Orignal NOKIA boxes which are very expensive $$$$,
Who need 3360 flash files can contact with me.
Best Regards,
Wahab
Old 05-22-2003, 10:17   #7 (permalink)
AWAIS's Avatar
Member: 16520
Sonork: 1580837
Thanks Meter: 90
wahab
does neelix also support nokia 1260 if it does'nt then
which sortwares support
Old 05-22-2003, 10:49   #8 (permalink)
DrMobile's Avatar
Member: 5932
Thanks Meter: 1,694
Originally posted by awais
wahab
NEELIX II can't flash 1260.
Best Regards,
Wahab
Old 05-23-2003, 09:46   #9 (permalink)
AWAIS's Avatar
Member: 16520
Sonork: 1580837
Thanks Meter: 90
then whick software supports nokia 1260
Old 05-23-2003, 09:50   #10 (permalink)
DrMobile's Avatar
Member: 5932
Thanks Meter: 1,694
At the moment non of the software support to Flash 1260 except ORIGNAL NOKIA EQUIPMENTS which are very ex*****ve around US$2500 to 5000
Best Regards,
Wahab
Old 05-23-2003, 11:44   #11 (permalink)
AWAIS's Avatar
Member: 16520
Sonork: 1580837
Thanks Meter: 90
hi wahab
do u have that equipment or can u give the address of any seller have that obove mentioned. i am waiting for your sooner response
Old 05-23-2003, 21:37   #12 (permalink)
iyass's Avatar
Member: 23534
Thanks Meter: 17
i tink neelix II will help
Old 05-24-2003, 07:41   #13 (permalink)
AWAIS's Avatar
Member: 16520
Sonork: 1580837
Thanks Meter: 90
are you sure about that neelix II will give support on nokia 1260
Old 08-29-2004, 13:11   #14 (permalink)
nobal1976's Avatar
Member: 71190
Sonork: 100.1580485
Thanks Meter: 87
hi all
can any person tell me the ringer points of nokia 3360 on pcb ; i have aproblam the ringer points on pcb are disable;
thanx advance
Old 10-21-2004, 17:49   #15 (permalink)
nobal1976's Avatar
Member: 71190
Sonork: 100.1580485
Thanks Meter: 87
hi all i have explore the ringer point in 3320 or 3360 pcb can any person want to help ,plz , post a jpg of 3360 pcb front side i wil pointout.
" 3310 no ring no vibra no light " rekha1255 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-07-2011 13:55
Nokia 3310 no vibra no ring no light M_Alin Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 11 06-06-2011 18:10
E800 no ring no vibra MTi-GsM Samsung Hardware Repair 1 08-16-2007 12:02
3510i no ring, no vibra, no lights. E&D Nokia Digital Core Technology 4 ( DCT-4 ) 4 12-01-2005 22:56
Sony J5 / no ring no vibra pali Sony Ericsson Hardware Repair 7 03-08-2003 17:04
Page generated in 0.21766 seconds with 10 queries
