05-22-2011, 07:45 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: IN FRONT OF YOU Age: 44
Member: 475440 Status: Offline Sonork: 1604067 Thanks Meter: 965 | Nokia 3500 after changing thavo and retu contact service need help log of mxkey scan Phone Type: RM-272 (Nokia 3500c) SW Version: V 07.21 05-11-08 RM-272 (c) Nokia. Imei plain: 35204102093145-5 Product Code: 0549241 Battery voltage: 4671 mV, current: 49 mA Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed TimeStamp: 2008-11-14T08:12:10Z SW Version: 07.21 Variant Version: 006 ProductProfile: RM272_0549241_07.21_006.spr Simlock: 0549241_simlock.bin Imei net: 352041020931455 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Self test log ufs info lgs MCU SW : V 07.21 05-11-08 RM-272 (c) Nokia. PPM SW : V 07.21 05-11-08 RM-272 (c) Nokia. MEA Product : Nokia 3500c Prd.Code: 0549241 Bpr.Code: 0548279 Prod.Sn : PJH345801 HW Vers : 2005 EM RETU : 32 EM TAHVO: 53 RFIC Ver: 17211721 DSP Vers: ICPR61_08w10 IMEI : 352041-02-093145-5 SL Serv : SIMLOCK SERVER VERSION 63 SL Conf : 244-07-00000000000 SL Prof : 0000000000000000 SL Count: 00 00 BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN Provider: Nokia Test;Finland self test |
05-22-2011, 07:50 | #2 (permalink) |
Member: 475440 Status: Offline Sonork: 1604067 Thanks Meter: 965 | cyclone box logs Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 2220010F89486F5628F498B1E72F99047C809F5D CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 191EC665 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x00EC220800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC2208 (Samsung), Size: 32MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: C0E691EA16A7593A9BB28832D7312A39F7ED668D APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... MCU Version V 07.21 MCU Date 05-11-08 Product RM-272 (Nokia 3500 classic) Manufacturer (c) Nokia. IMEI 352041020931455 Mastercode 5221401770 IMEI Spare 3A25400102394105 IMEI SV 3325400102394125F5000000 PPM V 07.21, 05-11-08, RM-272, (c) Nokia. , MEA PSN PJH345801 Product Code 0549241 Module Code 0203649 Basic Product Code 0548279 PSD 0000000000000000 RETU 32 TAHVO 53 AHNE 11 HW 2005 RFIC 17211721 DSP ICPR61_08w10 Failed to read info -> Failed to read extended info cyclone box self tests Selftests to proceed: 30 Passed ST_EAR_DATA_LOOP_TEST Passed ST_SIM_CLK_LOOP_TEST Failed ST_SIM_IO_CTRL_LOOP_TEST Passed ST_SLEEP_X_LOOP_TEST Passed ST_UEM_CBUS_IF_TEST Passed ST_KEYBOARD_STUCK_TEST Failed ST_CAMERA_IF_TEST Passed ST_BACKUP_BATT_TEST Failed ST_LPRF_IF_TEST Failed ST_LPRF_AUDIO_LINES_TEST Passed ST_CURRENT_CONS_TEST Passed ST_RADIO_TEST Passed ST_BACKLIGHT_TEST Passed ST_SIM_LOCK_TEST Passed ST_SECURITY_TEST Failed ST_BT_WAKEUP_TEST Passed ST_HOOKINT_TEST Passed ST_TAHVOINT_TEST Passed ST_SLEEPCLK_FREQ_TEST Passed ST_BTEMP_TEST Failed ST_BT_SLEEP_CLK_TEST Passed ST_EXT_DEVICE_TEST Passed ST_CDSP_RF_BB_IF_TEST Passed ST_CDSP_RF_SUPPLY_TEST Passed ST_CDSP_TX_IQ_TEST Passed ST_CDSP_TXC_DATA_TEST Failed to make Selftests -> Phone is not responding for Selftest Request |
05-22-2011, 10:32 | #7 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | as from ur selftest log problem is in retu , try to change retu with new one . make sure it's well soldered. but first remove retu & check solder pads of retu in mobile pwb. |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
