nokia 3500 insert sim Hi, I have a nokia its says insert sim card pls any solutions thanks |
check or change sim ic regards |
check sim connector. cleand with ctc. change sim ic. |
Any schematic? I have same problem. wich IC is SIM IC? |
check sim pin if still ok then try change sim ic or give jumper,,,,solved ur problem all the best |
Thanks gsmshare but i think you don't read the posts before my post. You said the same thing like the previous posts. Anyway, I solved the problem. Change the SIM IC. http://img57.imageshack.us/img57/5259/3500ceg7.th.jpg |
hello nokia 3500c insert sim problem but no glass ic track please give me solution |
brother change sim ic, correct solution no need to jumper ic |
