Old 10-28-2009, 16:35   #1 (permalink)
Member: 1122148
Thanks Meter: 35
nokia 3500c Flash is ok with HWk nut not swiching on
i have nokia 3500c i flash with hwk flash is ok but not swiching on the phone was water damage
1ST BOOT : C0,07 [Rm-272] [2.0.9.0]
RAPx ID : 000000010000022600010006010C192101001101
EM 1 ID : 00000232
EM 2 ID : 00000353
RAPx PBID : 0F30001368047F56A46B4892B193092D09E155AF
RAPx MODE : 00
RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1
RAPx ROID : 191EC665DFAAF68F
CMT 1ST Boot OK
CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1
CMT FLID0 : 00010041-00006A20, Amd 72NS256PD
CMT FLCNT : 00000000000000000000000000000000000000
CMT MCID0 : FFFF0000-00000000
CMT 2ND Boot OK
CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0
CMT KSIG0 : C0E691EA16A7593A9BB28832D7312A39F7ED668D
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
IMAGE : rm272__07.21.mcusw
CMT NOR Erase Area: 0x00000000-000006BF
CMT NOR Erase Area: 0x000006C0-0001FFFF
CMT NOR Erase Area: 0x00020000-0007FFFF
CMT NOR Erase Area: 0x00080000-000DFFFF
CMT NOR Erase Area: 0x00100000-001FFFFF
CMT NOR Erase Area: 0x00200000-0031FFFF
CMT NOR Erase Area: 0x00320000-0105FFFF
CMT NOR Erase Area: 0x01060000-01067FFF
CMT NOR Erase Area: 0x01068000-0107FFFF
CMT FLASH ERASE OK, Time: 00:49
Written: 10 Certificate(s)
CMT FLASH WRITE OK, Time: 01:26
Chip SECTOR_SIZE: 128k
Warning, Must be Used 128Kb Sector_Size CNT File
IMAGE : rm272__07.21.image_opv_bpa_128
CMT NOR Erase Area: 0x01520000-01FDFFFF
CNT FLASH ERASE OK, Time: 00:25
CNT FLASH WRITE OK, Time: 00:31
IMAGE : rm272__07.21.ppm_w
CMT NOR Erase Area: 0x01080000-0151FFFF
PPM FLASH ERASE OK, Time: 00:14
PPM FLASH WRITE OK, Time: 00:24
Flashing Completed, Rebooting Mobile
EM 1 ID : 00000232
EM 2 ID : 00000353
RAPx MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
Certificate: Rm-272_355747025988517_1028200935628_CCCCmt.bin
CER FLASH ERASE OK, Time: 00:00
CER FLASH WRITE OK, Time: 00:00
Certificate: Rm-272_355747025988517_1028200935628_HWCCmt.bin
Certificate: Rm-272_355747025988517_1028200935628_NPCCmt.bin
Certificate: Rm-272_355747025988517_1028200935628_RDCmt.bin
Certificate: Rm-272_355747025988517_1028200935628_VARIANTCmt.bin
Written: 5 Certificate(s)
Certificate(s) Write Done
any solution sir
Old 10-28-2009, 17:26   #2 (permalink)
octavyus's Avatar
Member: 242469
Thanks Meter: 503
Exclamation
you make full erase after full flash with diferent version
B.R
Old 10-28-2009, 19:28   #3 (permalink)
Member: 368446
Thanks Meter: 44
flash with the higher version
Old 10-29-2009, 10:38   #4 (permalink)
Member: 1122148
Thanks Meter: 35
iwhich the higher version
tell n=me which the higher version bcs i fash with 7.21
Old 10-29-2009, 10:46   #5 (permalink)
israrbjr's Avatar
Member: 748544
Sonork: 100.1601881
Thanks Meter: 173
chacket with f-bus cable if show local mode or test mode then chacketd power button......
Old 10-30-2009, 09:56   #6 (permalink)
Member: 1122148
Thanks Meter: 35
its not showing locel or test mode n i m using nokia 6300 cable
i not showing local mde or test mode n
Old 10-30-2009, 10:15   #7 (permalink)
israrbjr's Avatar
Member: 748544
Sonork: 100.1601881
Thanks Meter: 173
chacked hardwear by lcd changing
Old 10-30-2009, 11:05   #8 (permalink)
transpirit's Avatar
Member: 950964
Thanks Meter: 161
flsh with heigher version
Old 10-30-2009, 11:07   #9 (permalink)
software zone's Avatar
Member: 494167
Thanks Meter: 292
not psible with hwk.try to flash with jaf interface with same flash file it well b ok
Nokia 1661 flash is ok 100% best_unlocking Nokia Digital Core Technology 4 ( DCT-4 ) 9 11-14-2009 18:18
n95 flashed 100% ok with HWK, so all users need check their cables.... .:GSM International:. HWK 24 05-29-2008 06:35
chines nokia n95 flash read ok with infinity sahil2000ind Infinity-Box 1 10-22-2007 08:24
1100 flash ok with UFS3 but not swith on denard Nokia Hardware & Hardware Repair 9 10-07-2006 17:30
a55 flashing ok with freia, but not power on? luis035 E-Gold Based Phones 3 08-14-2004 09:18
Page generated in 0.20994 seconds with 9 queries
