nokia 3510i displays:stop,not charging need any ideas and any hellp :) |
look near the charging area of the phone... a little component with "k" on it. either replace or solder the two points togather.. fonefingz |
thanks but it's a fuse and everythink ok with it |
:cool: need any ideas and any hellp check zener diode, look for leak, remove this diode and fix problem ;) |
try another battery! (use original charger acp7/8/12) check btemp line(from battery connector) except fuse , zenner diode and a capacitor charging is done/controlled by UEM ! so is better one of this 3 parts to be defective than UEM BR |
