-   Nokia Hardware & Hardware Repair (http://forum.gsmhosting.com/vbb/f148/)
-   -   nokia 3510i not charging (http://forum.gsmhosting.com/vbb/f148/nokia-3510i-not-charging-246664/)
PSG 11-08-2005 15:29
hi
i have 3510i not charging
after connect charger there is no any message just no reaction
i flashed it, rehot, check ohm as in picture
how to fix it ?
PSG 11-08-2005 16:59
i made short curcut and phone is charging now, i wonder what can be wrong? too hot baterry etc, any idea? or i can leave it if working?
Medz 11-08-2005 17:53
Try another good battery , if it goes over heated too , flash it with pmm file and nothing more :)
GSMTEK 11-08-2005 18:32
the v100 the safty diode in a whole lot of 3510 I its bad solder and this one is there to protact the procesor ...
GSM Coolhawk 11-08-2005 23:44
@PSG
3510i behaves similar to 11xx and 23xx series. You have a faulty UEM, change it and rebuild IMEI.
Regards
Medz 11-09-2005 01:49
@Gsmtek .. V100 is a zenner diode to protect the UEM from over charging voltage and when it goes into faliure state it becomes shorted internaly to the ground , when he bridges the F100 (fuse) , the phone starts charging againe , if V100 failed it'll **** the fuse and the phone will not charge .
As " coollhawk " sayes it will be the UEM !! , I know from the 1st. but it is glued ! , and not every one can change it , thats why I was saying ( and nothing more ) .
GSMTEK 11-09-2005 07:47
yes but look @ v100 becouse a lot of those are bad solderd in 3510i they somtimes aren't connected on one side ;)
PSG 11-09-2005 09:55
thanks for info, but i was asking about that:
i made bridge and now phone charging, baterry is ok (not hot, and full charged) but what can be wrong if this bridge i made? as i read i think uem can be damage if power will be too high ?
GSMTEK 11-09-2005 16:43
Yes you can damage uem if power becomes to high so you have to replace the fuse
Page generated in 0.20910 seconds with 5 queries
