Old 11-08-2005, 16:29   #1 (permalink)
PSG
PSG's Avatar
Member: 27761
Thanks Meter: 43
nokia 3510i not charging
hi
i have 3510i not charging
after connect charger there is no any message just no reaction
i flashed it, rehot, check ohm as in picture
how to fix it ?
Old 11-08-2005, 17:59   #2 (permalink)
PSG
PSG's Avatar
Member: 27761
Thanks Meter: 43
i made short curcut and phone is charging now, i wonder what can be wrong? too hot baterry etc, any idea? or i can leave it if working?
Old 11-08-2005, 18:53   #3 (permalink)
Member: 39601
Thanks Meter: 13
Try another good battery , if it goes over heated too , flash it with pmm file and nothing more
Old 11-08-2005, 19:32   #4 (permalink)
Member: 7267
the v100 the safty diode in a whole lot of 3510 I its bad solder and this one is there to protact the procesor ...
Old 11-09-2005, 00:44   #5 (permalink)
GSM Coolhawk's Avatar
Member: 7751
Thanks Meter: 74
@PSG
3510i behaves similar to 11xx and 23xx series. You have a faulty UEM, change it and rebuild IMEI.
Regards
Old 11-09-2005, 02:49   #6 (permalink)
Member: 39601
Thanks Meter: 13
@Gsmtek .. V100 is a zenner diode to protect the UEM from over charging voltage and when it goes into faliure state it becomes shorted internaly to the ground , when he bridges the F100 (fuse) , the phone starts charging againe , if V100 failed it'll **** the fuse and the phone will not charge .
As " coollhawk " sayes it will be the UEM !! , I know from the 1st. but it is glued ! , and not every one can change it , thats why I was saying ( and nothing more ) .
Old 11-09-2005, 08:47   #7 (permalink)
Member: 7267
yes but look @ v100 becouse a lot of those are bad solderd in 3510i they somtimes aren't connected on one side
Old 11-09-2005, 10:55   #8 (permalink)
PSG
PSG's Avatar
Member: 27761
Thanks Meter: 43
thanks for info, but i was asking about that:
i made bridge and now phone charging, baterry is ok (not hot, and full charged) but what can be wrong if this bridge i made? as i read i think uem can be damage if power will be too high ?
Old 11-09-2005, 17:43   #9 (permalink)
Member: 7267
Yes you can damage uem if power becomes to high so you have to replace the fuse
nokia 3510i not charging happychappy Nokia Digital Core Technology 4 ( DCT-4 ) 11 08-14-2009 12:19
help..nokia 3510i not charging..6103 low signal xerwayne Nokia Hardware & Hardware Repair 3 03-17-2009 06:23
3510i not charging zinoubinabil Nokia Hardware & Hardware Repair 5 10-30-2004 00:18
3510i not charging tareshm Nokia Digital Core Technology 4 ( DCT-4 ) 0 09-04-2004 22:00
3510i not charging samanthe Nokia Hardware & Hardware Repair 3 02-20-2004 23:06
Page generated in 0.31475 seconds with 8 queries
