Nokia 3610 show not charging when connect with charger Nokia 3610 show not charging when connect with charger? Thanks shri |
"not charging" Hi shri It can be a couple of things that cause "not charging" your best bet it to get the service manual and go through it I think the 3610 pcb is almost the same as the 5210 not sure though don't get them in this country so get the manual and try Later D. :D |
@shri: Most common problem of Not Charging emidiatly after connecting charger is termal resistor failure. Check it first. PS: I assume that you are using tested and not Chineeeesssss charger. WBR b0ba |
