10-03-2005, 09:10 | #1 (permalink) |
Junior Member Join Date: Jan 2004 Age: 50
Member: 50348 Status: Offline Thanks Meter: 0 | Nokia 3650 Flashing Problem 1st Boot Ok, WD2, UPP: 0082 Fl0: 0x00000000-0x007FFFFF,0001257E,Amd 29BDS643GT Fl1: 0x02000000-0x027FFFFF,0001257E,Amd 29BDS643GT Fl2: 0x04000000-0x047FFFFF,25020040, Algorithm: w2_amd.fia, w2_cbusb.fia Algorithm Ok, MSID: 845A01151784E4CBF3D92C4D7C Decoded MSID: 3E4EBAF7-00C2CD71-A8000000 Encoded FAID: F8888C4D-A79C5EEE-101E5F75 Area1: 0x00000000-0x0000FFFF Erased, Time: 00:00 Area2: 0x00010000-0x006FFFFF Erased, Time: 01:13 Area3: 0x02000000-0x023FFFFF Erased, Time: 00:41 Erasing: 0x04000000-0x046DDFFF ... Erasing Error: 10, at: 0x04000000-0x0401FFFF, 940207, Time: 00:00 Process Failed, Repowering Mobile CAN ANYONE ONE HELP ME OUT |
10-03-2005, 11:51 | #3 (permalink) |
No Life Poster Join Date: May 2004 Location: A ROUGH ROAD LEADS 2 THE STARS
Member: 66937 Status: Offline Thanks Meter: 5,053 | hi HI GUY'S PROBLAM IS 1st Boot Ok, WD2, UPP: 0082 Fl0: 0x00000000-0x007FFFFF,0001257E,Amd 29BDS643GT Fl1: 0x02000000-0x027FFFFF,0001257E,Amd 29BDS643GT Fl2: 0x04000000-0x047FFFFF,25020040, EASY TO UNDERSTAND 3RD FLASH NOT WORKING RESOLD IT AN FLASH PHONE WILL BE OKI..... ANY HELP MUNNA [email protected] +919810626677 www.gsmmunna.com |
10-03-2005, 17:04 | #5 (permalink) | |
Freak Poster Join Date: Dec 2002 Location: Philippines Age: 65
Member: 19076 Status: Offline Thanks Meter: 0 | Flash Ic Identity Quote:
Hello, I also have the same problem, since it appears you know exactly which FLASH IC is DEFECTIVE! Can you help me IDENTIFY the following using the 3650 schematic component identification: D313 - is FLASH IC # D311 - is FLASH IC # D310 - is FLASH IC # Thank you for the help! Best regards, loloph | |
10-04-2005, 12:15 | #7 (permalink) |
Member: 50348 Status: Offline Thanks Meter: 0 | Hello Munna Thanks For Suggestion But This Happened When I Was Upgrading It , So Cat It Be Hardware Problem . If Possible Can U Post 3650 Circuit Diagram Which Shows The Faulty Ic |
10-04-2005, 13:50 | #8 (permalink) |
Member: 66937 Status: Offline Thanks Meter: 5,053 | hi NO NEED ANY PRINT OUT JUST TAKE OUT ALL 3 AMD AND REBALL THEN AN FLASH. IT MAY ALSO COZE OF BAD RAM WHILE TAKE 3 AMD OUT TAKE OUT THE RAM ALSO REBALL IT AN FLASH PHONE AM 100% SURE YR PROBL;AM WILL BE SOLVE.... 3650 IS VERY TIPICAL SET YOU MAY ALSO NEED FULL ERASE FLASH FILE TO FORMAT ALL FLASH AREA BEFORE FLASHING...... ALL MY BEST REGARD'S WITH YOU YOU CAN CONTACT ME ANY TIME WBR MUNNA +919810626677 MAIL:- [email protected] www.gsmmunna.com |
Nokia 3650 flashing problem !!! Pls help | ocean0 | Nokia Hardware & Hardware Repair | 1 | 07-24-2006 07:35 |
nokia 3650 flashing problem | HUM | WD2 & APE (Symbian Phones) | 2 | 09-12-2005 21:49 |
3650 flashing problem, HW problem | Trixxie | Nokia Hardware & Hardware Repair | 8 | 07-05-2004 10:54 |
Nokia 3650 Memory Problem | Rangers | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 09-16-2003 14:11 |
