05-06-2004, 22:19 | #1 (permalink) |
No Life Poster Join Date: Nov 2001 Location: Mauritius Age: 47
Member: 7482 Status: Offline Thanks Meter: 24 | NOKIA 3650 Hardware Failure can anyone help me please i am getting a problem with a NOKIA 3650 it says HARDWARE FAILURE each time i try to start Camera or Video Recording fuction Please can anyone help is it hardware or software problem? WBR |
05-07-2004, 07:05 | #3 (permalink) |
Member: 7482 Status: Offline Thanks Meter: 24 | yes tried to flash it and also i have write new PM is there another PM that i can write i got that PM to repair 4x blinking is there another one which has to be used? Thanks for reply WBR |
05-08-2004, 01:16 | #4 (permalink) |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | [QUOTE=Mehvishal]yes tried to flash it and also i have write new PM is there another PM that i can write i got that PM to repair 4x blinking is there another one which has to be used? Thanks for reply hi., 1- change the camera with working 100% one if not.. 2- check connection with camera and board pins if not ... 3- camera hardware accelrator ic in the u left of the uem if not ... 4- circute of the camera pins and the hardware accelrator ic if not... 5- check the upp final .. must the problem solved notsofware problem br., |
05-08-2004, 16:24 | #5 (permalink) |
Insane Poster Join Date: Apr 2004
Member: 61249 Status: Offline Thanks Meter: 0 | Hi in my experience most of the time this hardware failure problem comes from Hardware accelerator IC. After replaced the HW Accel IC if it shows same problem or BLANK WHITE SCREEN it can be from bad UPP or UEM. Try ur Best Bestregards Techman |
05-08-2004, 20:02 | #6 (permalink) | |
Member: 7062 Status: Offline Thanks Meter: 126 | Quote:
what the relation between the uem and the camera functions if any relation what the benefit and the job of the hardware accelratour ic ????????????????? br., | |
05-09-2004, 06:43 | #7 (permalink) |
Member: 61249 Status: Offline Thanks Meter: 0 | rE: @Rahbeeb two power supply voltages (Vaux2=2.8, Vcore=1.8v) need to work camera, these Voltages coming to the camera through HW Accelerator. But to work HW Accelerator it needs Vcc , and the Vcc is voltage is supplied throug two capacitors by UEM. This is explained in the Flow chart. Touble shoot with this and i am sure u will be succeeded. Bestregards techman |
05-09-2004, 07:09 | #8 (permalink) | |
05-10-2004, 08:41 | #11 (permalink) | |
Administrator Join Date: Jul 2002 Location: E G Y P T Age: 38
Member: 14178 Status: Offline Thanks Meter: 8,862 | Quote:
1- change the camera with working 100% one if not.. 2- check connection with camera and board pins if not ... 3- camera hardware accelrator ic in the u left of the uem if not ... 4- circute of the camera pins and the hardware accelrator ic if not... 5- check the upp final .. must the problem solved notsofware problem yeah you did step no1 thank *** it was not the uem | |
nokia 6600 hardware failure restart camera | ibraheem0079 | Nokia Hardware & Hardware Repair | 16 | 05-17-2012 15:37 |
help me camera 3650 " hardware failure : Restart Camera " | edi wijaya | Nokia Hardware & Hardware Repair | 2 | 08-23-2008 11:09 |
Nokia 3650 Hardware Failure | Mehvishal | UFS2 + UFS3-Tornadoflasher | 7 | 04-10-2005 15:35 |
Nokia 3650 Hardware Failure | Mehvishal | WD2 & APE (Symbian Phones) | 4 | 03-21-2005 08:19 |
NOKIA 3650 - 7250 Camera Failure | RDTEL | WD2 & APE (Symbian Phones) | 1 | 12-11-2003 19:00 |
