Old 02-15-2005, 13:34   #1 (permalink)
Member: 103177
Nokia 3650 problem
Hi.....
I have got a 3650 ....now it is powering on and stay on the first screen NOKIA .... how to fix this problem
Thank's in advance for your reply !
isara
Old 02-15-2005, 16:02   #2 (permalink)
Member: 63385
Thanks Meter: 3
Try to flash the phone...
Chill!
merulez29
Old 02-15-2005, 16:08   #3 (permalink)
Member: 82155
Thanks Meter: 33
just try to format user area and thats all
Old 02-16-2005, 14:05   #4 (permalink)
Member: 103177
i tried it...it didn`t work
now the nokia sign blinking 4 times.....
Old 02-16-2005, 14:38   #5 (permalink)
desmond2727's Avatar
Member: 58704
Sonork: 100.1618753
Thanks Meter: 43
Hi mate
u need to check the cable if that cable ok u need do erase flash,FLash MCU,PPM.After that write PM n unlock..
try it....
good luck...
Old 02-17-2005, 07:47   #6 (permalink)
Member: 63385
Thanks Meter: 3
Try this:
- reheat UPP
- erase flash using special .bin file via PPM
- write good PM, Init Simlocks & Full Factory
- Format User Area
I have encountered this problem and remedied thru Twister. Apply ample temp in reheating UPP.
merulez29
Old 02-17-2005, 13:38   #7 (permalink)
Member: 103177
i`ve tried it...d same problem still occured. well thx 4 u`r help i think i`ve to change my fone...
thx all
Old 02-17-2005, 13:58   #8 (permalink)
LoopyTT's Avatar
Member: 93240
Thanks Meter: 8
for me was same prob with ngage.. format user area, full factory reset.. and works.. if is not try to flash.. you prob is ONLY soft
respect
Old 02-17-2005, 14:40   #9 (permalink)
Member: 25763
Thanks Meter: 18
@isarapearl
Hi
Try an old method
1. Flash the phone ppm only with chinese mcu+ppm combined file.
2. Flash European Pack
3. Write good pm
4. Init Locks
5. Do all UI settings
If all of the above does not work,try to service the phone and again do a software flashing.
Regards
nokia 3650 Problem GazI WD2 & APE (Symbian Phones) 12 12-01-2004 17:04
SIM MENU and Nokia 3650 problem Maxim Gavrilov WD2 & APE (Symbian Phones) 5 06-03-2004 15:51
Nokia 3650 problems Nokall UFS2 + UFS3-Tornadoflasher 6 05-24-2004 04:29
nokia 3650 problem. imei is ??????????? pls help spikerman Nokia Multimedia 2 12-15-2003 13:49
Nokia 3650 V2.50 flashing problem saejor Nokia Digital Core Technology 4 ( DCT-4 ) 0 03-06-2003 02:38
Page generated in 0.19593 seconds with 10 queries
