05-20-2007, 16:53 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Faisalabad, Pakistan Age: 41
Member: 248050 Status: Offline Sonork: 100.1624328 Thanks Meter: 140 | Insert SIM repair by change battery I found new solution for repair insert sim tested on 1100, 2300, 1110, 1112, 6030 etc. I check IC but it ok than check SIM jack & clip but all is ok but still insert sim so I just change battery than insert sim problem solved. I don't know reason but it really work. so try and post your comments and why it work?. Kind regards, Vicky |
05-21-2007, 14:00 | #6 (permalink) | |
Registered User Join Date: Apr 2007
Member: 483748 Status: Offline Thanks Meter: 47 | Quote:
yes it is possible to solve that type of problem some times it is due to board connecter some times is due to batter bsi pin itself. how can we solve it, is it ic problem or bsi problem? 1.if it is sim ic problem then insert sim appears quickly. 2. if it is bsi then it take little bit time to show insert sim. | |
05-21-2007, 19:30 | #7 (permalink) |
No Life Poster Join Date: Dec 2004 Location: india Age: 40
Member: 101117 Status: Offline Thanks Meter: 466 | yaa its due to the middle point of the battry connector if the battry wont touch the middle point of battry connector so it shows insert sim so 1st solution is clean battry contacts 2nd take out the middle point of battry connector with the plucker |
05-23-2007, 08:17 | #8 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: http://meo786.forumotion.com/ Age: 50
Member: 465162 Status: Offline Thanks Meter: 683 | Very nice tip Thanks brother Quote:
05-23-2007, 17:28 | #10 (permalink) | |
Member: 248050 Status: Offline Sonork: 100.1624328 Thanks Meter: 140 | Quote:
BR Vicky | |
6030 insert sim i try chang ic then remove and make jumper but same insert sim | shani72 | Nokia Hardware & Hardware Repair | 7 | 01-20-2010 06:06 |
Nokia Insert SIM Solution BY STBSL | zeeshanawan | Nokia Hardware & Hardware Repair | 12 | 01-19-2009 22:16 |
insert sim after imei change | selfbox | Universalbox | 2 | 12-05-2007 22:03 |
X820 insert sim repair help | bcnboy | NSPRO | 2 | 05-08-2007 20:00 |
nokia6600 insert sim repairing photo | 786786 | Nokia Multimedia | 1 | 12-04-2005 16:07 |
