Old 11-13-2013, 15:48   #1 (permalink)
Member: 1773388
Sonork: aeyna
Thanks Meter: 2
nokia 500 big problem plz help
open camera show= unexpected error occurred. Please restart the camera. If this does not help, try restarting the phone.
Old 11-13-2013, 18:54   #2 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
seems hardware issue , first remove & clean camera module & connector then check . also post here selftest result.
there is two camera regulator used in nokia 500 . one is N1420 for vcam 1.8v & another is N1421 for vcam 2.8v supply to camera module .
if these voltages r missing then also camera problem aries . so check vcam 2.8v at L1042 & check vcam 1.8v at L1403 (marked in attach picture) .
if any of these voltage found missing or abnormal then u need to replace it's regarding regulator . (u may also bypass these two voltages without these regulators but I advice u to replace )
post here result .
The Following User Says Thank You to .:SARCAR:. For This Useful Post:
Page generated in 0.11789 seconds with 9 queries
