Old 04-07-2014, 16:20   #61 (permalink)
Member: 1359325
Sonork: 470928
Thanks Meter: 9
try this solution 100% tested nokia 500 restart
http://forum.gsmhosting.com/vbb/f148.../#post10222242
Old 07-01-2014, 08:56   #62 (permalink)
Member: 1655874
Thanks Meter: 13
http://www.4shared.com/photo/td3haHX...cture_124.html
change the pf ic 100% tested
the pf ic can be taken from nokia 6303 (or) nokia E6
The Following User Says Thank You to vallimurugan For This Useful Post:
Old 09-14-2014, 10:02   #63 (permalink)
Member: 1648285
Thanks Meter: 5
Originally Posted by Binilraj View Post
Guys That is not hardware or R F ic prob.it is sw related.pls do the hand set file system format through phoniex or other dongles it will work
Regards
Binilraj.M.N
GUYS dnt post if u dont know the exat solution........... its 100% PF RELETED COMPLAIN...
Old 11-17-2014, 00:23   #64 (permalink)
Member: 1923273
bro.. which one pa in Nokia 500 that i can check plz help
Old 12-06-2014, 07:55   #65 (permalink)
mahzra azra's Avatar
Member: 1722956
Sonork: mybestfriend.adeel
Thanks Meter: 305
i got same kind of problem set and i am going to repaire this after repaire i will tell you solve you.
my problem is -- when i insert sim and make call set go off wnd without sim card
make 112 call set go in off.
wait for a minut.
Old 12-06-2014, 14:06   #66 (permalink)
Member: 1722956
Thanks Meter: 305
i have done my set ,now every thing is ok network problem solved and i can make any call.
if anyone need to solve this problem contect me--------
Old 12-06-2014, 17:04   #67 (permalink)
Member: 2240757
Thanks Meter: 55
Bro...its not PA problem...its other hardware problem.....anybody solutionjust contact me...
I will try your problem solving....
My contact number . 01758025314
Many phone its problem solve me...
Gsm Masum
Only thanks button
Old 12-16-2014, 05:51   #68 (permalink)
Member: 1022602
Thanks Meter: 10
i have same problam i flash infinty best,cyclon.atf but problam still any one have solutions pls help
Old 02-09-2015, 04:02   #69 (permalink)
Member: 844312
Sonork: 100.1640471
Thanks Meter: 257
this is a network ic problem alredy remove but sameproblem
Old 02-09-2015, 04:09   #70 (permalink)
Member: 844312
Sonork: 100.1640471
Thanks Meter: 257
http://forum.gsmhosting.com/vbb/f148.../#post10222242 this is ic al;redy removed same problem bro need 100% solution
Old 02-09-2015, 04:12   #71 (permalink)
Member: 844312
Sonork: 100.1640471
Thanks Meter: 257
correct solution sim not running handset off line handset runing
Old 01-23-2016, 00:06   #72 (permalink)
Member: 998606
Sonork: nadir
Thanks Meter: 2
This is th pa ic problem pa means power amplifier of network when signal comes on the phone pa will short and mobile become short so change pa and solve your problem
Old 03-18-2016, 10:10   #73 (permalink)
anuhya anu's Avatar
Member: 2540337
Thanks Meter: 39
Nokia 500 insert sime when auto restarted , i tried flash with latest same product code , and checked batter, but without sim working fine mobile , any solustion
Page generated in 0.23748 seconds with 9 queries
