11-04-2009, 14:38 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: India
Member: 449060 Status: Offline Sonork: 100.1670591 Thanks Meter: 260 | nokia 5000 help MCU ID: 0x3162 FLASH ID0: 317E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1B 00 FF 10 40 00 00 00 00 00 00 00 00 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-362\ Searching for default location of ini... Checking path: \Products\RM-362\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-362\ Scanning ini files... Checking path: \Products\RM-362\ Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-362\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-362\rm362__05.45.mcusw PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-362\rm362__05.45.ppm_aa CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-362\rm362__05.45.image_aa_blu ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Dannish,Norwegian,Swedish Changing flashing settings... Checking path: \Products\RM-362\ Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-362\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-362\rm362__05.45.mcusw PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-362\rm362__05.45.ppm_mm CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-362\rm362__05.45.image_mm_blu ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Backing up PM Field 208 as RPL... Setting local mode... Reading IMEI... Reading IMEI data... Building RPL backup file... C:\Program Files\ODEON\JAF\ProgData\356797022617881_imei_back up_1152411.rpl Done! Backup imei OK! MCU: C:\Program Files\Nokia\Phoenix\Products\RM-362\rm362__05.45.mcusw Booting phone... MCU ID: 0x3162 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 317E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11 FLASH ID1: 317E0001 <=> SPANSION -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 11 First 16 bytes: AD 7E B6 1B 00 FF 10 40 00 00 00 00 00 00 00 00 Flash ID is 0x7E310100 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: a2 Loader is ready... P-key nokia module version 01.02 MSID: 84ACED1B47CF712480E0C69B74 MSID decoded: 2C40BAE90041BAA3AA000000 FAID: 1A006C1E42B09477F8B64435 Operation took 0 minutes 8 seconds... Erasing... Found 2 interval(s) to erase Erasing area: 01000000 - 0101FFFF... Erasing area: 01020000 - 01BFFFFF... Operation took 0 minutes 56 seconds... Writing... Perm. Data Restore OK Operation took 4 minutes 5 seconds... Restarting MCU... CNT: C:\Program Files\Nokia\Phoenix\Products\RM-362\rm362__05.45.image_mm_blu Booting phone... MCU ID: 0x3162 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 317E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11 FLASH ID1: 317E0001 <=> SPANSION -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 11 First 16 bytes: AD 7E B6 1B 00 FF 10 40 00 00 00 00 00 00 00 00 Flash ID is 0x7E310100 File is already converted to 128k page... Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: a2 Loader is ready... P-key nokia module version 01.02 MSID: 846507BD0F376F16ABFCBBAA52 MSID decoded: D26EBAF10041BAA3AA000610 FAID: 421902CAA17646B22F79F12C Operation took 0 minutes 8 seconds... Erasing Content Pack... Found 2 interval(s) to erase Erasing area: 02180000 - 02E7FFFF... Erasing area: 02E80000 - 02FBFFFF... Operation took 2 minutes 47 seconds... Writing... Perm. Data Restore OK Operation took 1 minutes 40 seconds... Restarting MCU... Operation took 0 minutes 1 seconds... Extracting Content Pack... Running: (c) Nokia File Server CNT Extract OK. Operation took 0 minutes 4 seconds... PPM: C:\Program Files\Nokia\Phoenix\Products\RM-362\rm362__05.45.ppm_mm Booting phone... MCU ID: 0x3162 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 317E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11 FLASH ID1: 317E0001 <=> SPANSION -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 11 First 16 bytes: AD 7E B6 1B 00 FF 10 40 00 00 00 00 00 00 00 00 Flash ID is 0x7E310100 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: a2 Loader is ready... P-key nokia module version 01.02 MSID: 847636551B0DC83A9FE9122068 MSID decoded: 3E4EBAE90041BAA3A8000000 FAID: 37ACEBC6392F4DCA354CBDF2 Operation took 0 minutes 9 seconds... Erasing PPM... Found 1 interval(s) to erase Erasing area: 01C00000 - 0217FFFF... Operation took 0 minutes 35 seconds... Writing... Perm. Data Restore OK Operation took 1 minutes 40 seconds... Restarting MCU... Flashing Done! Operation took 12 minutes 25 seconds... After flash processing... Waiting for phone to boot... Reading... Phone type: RM-362, Software version: 05.45 IMEI: 356797022617881 Product Code: 0568540 Resetting PPC... Setting FULL FACTORY......Setting test mode... Setting FULL FACTORY... Operation took 0 minutes 4 seconds... Done! Done! Done! help but can not power on phone i try chraging but not show charging help sir |
11-04-2009, 17:59 | #4 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Bangladesh Age: 38
Member: 1003058 Status: Offline Sonork: 100.1589274/mahbubalfa Thanks Meter: 26,433 | Quote:
help schematics Nokia 5000 | Gsm Hưngyên | Nokia Hardware & Hardware Repair | 4 | 10-28-2010 17:05 |
help nokia 5000 prblem | sajjadahmad | Universalbox | 5 | 11-18-2009 13:25 |
Problem unlock Nokia 5000!!!! Please help | tommyvo | Cyclonebox | 8 | 06-25-2009 08:36 |
nokia 5000 problem charge any solution please help | samirtelecom | Nokia Hardware & Hardware Repair | 1 | 02-08-2009 12:10 |
Help unlocking nokia 5000-d rm 362 | gsmservices | MT-BOX | 6 | 01-01-2009 20:14 |
