Nokia 5030 Auto Restart Solution Hello My Set Nokia 5030 Auto Restart Problem Any Solution Of This Problem Please Give Me Thanks. |
sw update, full factory setting, good pm Thank You Byte ----- Cheap Hosting Web Hosting Services, Reseller Hosting, and Dedicated Servers by HostGator |
its common problem in 5030,1661 and 1202 auto restart problem comes due to several reasons i didnt solve this problem from specific place sometimes it comes due to dust sometimes bad contact between upp and pcb sometimes bad uem and flash ic sometimes internally pcb break |
1202 contact service hardwear selution |
bro try to rehot upp..... |
5030 flash successfull by mx key Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung K8S6415ETC,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00963FBC:DA3BDA66 ASIC type: 11 UEM Imei: 35825703130235 Processing file: rm524_005.010 as MCU [DCT4,DCT4 ALGORITHM] size: 2.37 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung K8S6415ETC,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00963FBC:2984DA60 Area [01000000-0100FFFF] erased in 0.406 s Area [01010000-0179FFFF] erased in 48.610 s Area [017A0000-017EFFFF] erased in 2.219 s Area [01F00000-01FDFFFF] erased in 0.766 s Flash programming ... Programming completed in 21.469 s File Processed in 1 min 23.671 s Processing file: rm5240_nai05.01ec as CNT [DCT4,DCT4 ALGORITHM] size: 172.65 KB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung K8S6415ETC,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00963FBC:2984DA60 Area [01750000-0178FFFF] erased in 1.718 s Flash programming ... Programming completed in 1.844 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.328 s File Processed in 27.297 s Processing file: rm524_005.01ia as PPM [DCT4,DCT4 ALGORITHM] size: 2.82 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung K8S6415ETC,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00963FBC:2984DA60 Area [01250000-0125FFFF] erased in 0.407 s Area [01260000-0174FFFF] erased in 31.437 s Flash programming ... Programming completed in 24.969 s File Processed in 1 min 9.016 s Flashing completed in 3 min 44.031 s Phone Type: RM-524 SW Version: V 05.01 23-09-09 RM-524 (c) Nokia Imei plain: 35825703130235-3 Product Code: 0578242 Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: IA Language Pack: - not available. Imei net: 35825703130235 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Total time to process is 3 min 57.047 s |
hello guyz please help me i m a big problem for nokia 5030 restart after 1 mint without sim card and with sim card kindly give me any solution |
yes i also replaced uem upp and reballed flash ic but sill same. as mentioned in the start of this thread. changed rtc and 2600MHz crystel. not cleared yet. may be board is internaly damage. |
hello everybody , i have nokia 5030 restrting problem ,give me any soln |
5030 restart []hello everybody , i have nokia 5030 restrting problem ,give me any soln[/QUOTE] |
hihihihi very simpal; solution contact me 100% |
