Old 07-27-2010, 15:06   #1 (permalink)
~The JoKeR~'s Avatar
Member: 1051835
Sonork: 100.1594332
Thanks Meter: 514
Arrow Nokia 5030 Auto Restart Solution
Hello
My Set Nokia 5030 Auto Restart Problem
Any Solution Of This Problem
Please Give Me
Thanks.
The Following 2 Users Say Thank You to ~The JoKeR~ For This Useful Post:
Old 07-27-2010, 21:55   #2 (permalink)
Member: 39208
Thanks Meter: 150
sw update, full factory setting, good pm
Thank You
Byte
Cheap Hosting
Web Hosting Services, Reseller Hosting, and Dedicated Servers by HostGator
The Following User Says Thank You to Byte For This Useful Post:
Old 07-27-2010, 22:51   #3 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,230
its common problem in 5030,1661 and 1202
auto restart problem comes due to several reasons
i didnt solve this problem from specific place
sometimes it comes due to dust
sometimes bad contact between upp and pcb
sometimes bad uem and flash ic
sometimes internally pcb break
The Following User Says Thank You to HUM For This Useful Post:
Old 07-28-2010, 06:19   #4 (permalink)
Registered User
Member: 820730
Thanks Meter: 7
1202 contact service hardwear selution
The Following User Says Thank You to m.ilyas For This Useful Post:
Old 07-28-2010, 06:21   #5 (permalink)
suraj9860607689's Avatar
Member: 787710
Sonork: not using
Thanks Meter: 765
bro try to rehot upp.....
Old 09-06-2010, 15:14   #6 (permalink)
dilshad_noori's Avatar
Member: 1293519
Sonork: 100.1596500
Thanks Meter: 169
5030 flash successfull by mx key
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
ASIC ID: 0x2293 [UPPCosto ver: 2.0]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 00EC 2254 [Samsung K8S6415ETC,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514
Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0
Performing Flash Authentication ...OK
UEM ID: 00963FBCA3BDA66
ASIC type: 11
UEM Imei: 35825703130235
Processing file: rm524_005.010 as MCU
[DCT4,DCT4 ALGORITHM] size: 2.37 MB
Supported Ids: 2293
UEM ID: 00963FBC:2984DA60
Area [01000000-0100FFFF] erased in 0.406 s
Area [01010000-0179FFFF] erased in 48.610 s
Area [017A0000-017EFFFF] erased in 2.219 s
Area [01F00000-01FDFFFF] erased in 0.766 s
Flash programming ...
Programming completed in 21.469 s
File Processed in 1 min 23.671 s
Processing file: rm5240_nai05.01ec as CNT
[DCT4,DCT4 ALGORITHM] size: 172.65 KB
Supported Ids: 2293
Area [01750000-0178FFFF] erased in 1.718 s
Programming completed in 1.844 s
Extracting Content Pack, File Server fake reply for CUI phone.
Content Pack extracted successfully in 0.328 s
File Processed in 27.297 s
Processing file: rm524_005.01ia as PPM
[DCT4,DCT4 ALGORITHM] size: 2.82 MB
Supported Ids: 2293
Area [01250000-0125FFFF] erased in 0.407 s
Area [01260000-0174FFFF] erased in 31.437 s
Programming completed in 24.969 s
File Processed in 1 min 9.016 s
Flashing completed in 3 min 44.031 s
Phone Type: RM-524
SW Version: V 05.01 23-09-09 RM-524 (c) Nokia
Imei plain: 35825703130235-3
Product Code: 0578242
Cellular System: GSM
ASIC ID: 0x2293, type: 11
Ppm Id: IA
Language Pack:
- not available.
Imei net: 35825703130235
Version: SIMLOCK SERVER
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000030002
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
Total time to process is 3 min 57.047 s
The Following User Says Thank You to dilshad_noori For This Useful Post:
Old 11-13-2010, 14:18   #7 (permalink)
abdullahnokia's Avatar
Member: 330559
Thanks Meter: 63
hello guyz please help me i m a big problem for nokia 5030 restart after 1 mint without sim card and with sim card kindly give me any solution
Old 04-26-2011, 14:37   #8 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 942
yes i also replaced uem upp and reballed flash ic but sill same. as mentioned in the start of this thread. changed rtc and 2600MHz crystel. not cleared yet. may be board is internaly damage.
Old 04-30-2011, 06:38   #9 (permalink)
Member: 1566425
Sonork: javid_rafiq1992
[email protected]
Old 08-14-2011, 05:35   #10 (permalink)
Member: 1471424
Thanks Meter: 2
hello everybody , i have nokia 5030 restrting problem ,give me any soln
Old 07-20-2013, 18:06   #11 (permalink)
Member: 1959118
Sonork: aru
5030 restart
[]hello everybody , i have nokia 5030 restrting problem ,give me any soln[/QUOTE]
Old 07-21-2013, 17:49   #12 (permalink)
ashish800's Avatar
Member: 1889562
Thanks Meter: 591
hihihihi very simpal; solution contact me 100%
Seeking for flash nokia 5110 old version (3 version) can exchange for new Tomas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 10-14-2017 20:29
Page generated in 0.38926 seconds with 8 queries
