Old 07-02-2010, 02:21   #1 (permalink)
thomp4pal's Avatar
Member: 292106
Sonork: 100.1582885
Thanks Meter: 116
Nokia 5030 strange keypad problem
Many times i solve keypad problems by change K.P ic, but this one is very strange,. this phone is fresh board.. When u press any number key its shows the number u pressed then add six to it, for example u press 1, it shows 1,6. secondly navigation and softkeys not working, when u press radio botton it shows "6",. I have changed 3 keypad ic, Rehot cpu, removed volume and radio switchs, still not solved...
Anyone come across this strange problem?..How u solve pls pls.
The Following User Says Thank You to thomp4pal For This Useful Post:
Old 07-02-2010, 07:31   #2 (permalink)
Member: 1300401
Sonork: 2+2=4
Thanks Meter: 16
dear brother keypad ic shorting . check your ic or inmother board ic print check it
. 100 %%% ic or ic print problem .
The Following User Says Thank You to firosnbr For This Useful Post:
Old 07-02-2010, 10:09   #3 (permalink)
thomp4pal's Avatar
Member: 292106
Sonork: 100.1582885
Thanks Meter: 116
i change many times..new tested keypad ic...not solved
Old 07-02-2010, 20:03   #4 (permalink)
Registered User
Member: 1087294
Thanks Meter: 252
check all point of keypad ic on board for shorting not change keypad ic make keypad ic jumper after five jumpers check keypad if ok make another jumper and check after every jumper i solved that type of prob in 1110 two times i already changed two ics but result same then i make jumpers of ic try it i think your prob solved
must reply
Old 07-04-2010, 11:59   #5 (permalink)
thomp4pal's Avatar
Member: 292106
Sonork: 100.1582885
Thanks Meter: 116
k, i try jummper and post results later
Old 08-24-2010, 06:35   #6 (permalink)
Member: 1228162
thanksss keypad is ok .par broo right key button nahi chal raha.solution toh mil gaya par jo shorting karni hai vahan par soldering nahi ho rahi..... pls help me
Old 08-24-2010, 06:39   #7 (permalink)
Member: 1228162
chek the ways on front of board 1000% . check the ways of 1and 6 and others
Old 10-01-2010, 14:19   #8 (permalink)
Member: 1387850
Sonork: ZPM
Thanks Meter: 3
5030 keypad problem
menu 9 * 0 # keys not working solve me immediately
The Following User Says Thank You to prashanth4u For This Useful Post:
Old 10-01-2010, 14:23   #9 (permalink)
Member: 1387850
Sonork: ZPM
Thanks Meter: 3
1650 keypad problem
menu 9 * 0 # solve immediately
Old 10-01-2010, 14:57   #10 (permalink)
Member: 500885
Thanks Meter: 77
Originally Posted by prashanth4u View Post
1650 keypad problem
bro change the k pad ic stil the same bro chk keypad track in the pic no solve it just rehot the cpu
The Following User Says Thank You to m.bala For This Useful Post:
Old 10-01-2010, 15:01   #11 (permalink)
Member: 1261393
Sonork: ..::KISHANGANJ ::..
Thanks Meter: 13
4 nokia 5030, pls change volume switches, this causes 4 kepad probleme.
The Following User Says Thank You to teamviewer For This Useful Post:
Old 12-05-2010, 13:01   #12 (permalink)
debapra_gsm's Avatar
Member: 1247853
Thanks Meter: 71
just change all side keys........ur problem will solve.....1000000000%
Old 12-08-2010, 07:00   #13 (permalink)
Member: 1130798
Sonork: no
Thanks Meter: 10
The Following User Says Thank You to anjanreddy For This Useful Post:
Old 03-19-2011, 19:16   #14 (permalink)
Crazy Poster
Member: 1539909
Thanks Meter: 5
i have got og keypad ways on u2ugsm.com ucan see it
i will upload it here wait for my reply
Old 04-16-2011, 14:16   #15 (permalink)
Member: 974973
Thanks Meter: 2
anjanreddy
Member: 1130798
Sonork: no
thanx bro u r righet
Page generated in 0.24123 seconds with 10 queries
