05-19-2011, 11:13 | #3 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | check power on keypad via multimeter weather it's shorted with ground or not , if shorted with ground remove or replace keypad esd filters then check. if not solve d problem after replace keypad esd filter u need to replace avilma. post result |
05-19-2011, 20:04 | #4 (permalink) |
Freak Poster Join Date: Apr 2011
Member: 1553201 Status: Offline Thanks Meter: 9 | do this you will succsess it is actual reason of this problems 1. remove keypad ic which is related on power key ,if set not on automatic then its 100% sure that avilma , betty sections is ok.put new keypad ic and its ok. 2.if after remove key pad ic stil the problem same, then problem in power on track .that means in power tracks some filter capacitors or vdr getting leakage short and that is why power key voltage getting ground and the set automatic power on. 3. before all you must look that pcb is water damage or not. 4.after all you have to change betty ,avilma |
