09-12-2009, 16:00 | #21 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Abuja, Nigeria west Africa. Age: 52
Member: 129947 Status: Offline Thanks Meter: 16 | please i have a 5310 contact service flash ok with latest file but still the same. Please how can i write rpl need step on how to use jaf to write rpl. Thanks in advance. |
09-17-2009, 16:14 | #24 (permalink) |
No Life Poster Join Date: Apr 2009 Location: gadgets works station
Member: 1019591 Status: Offline Sonork: 100.1592733 Thanks Meter: 634 | bro if you have mxkey , first sx4 and write pm. if in this process not solved please then update your simlock/ repair. try this processs if not solved , the last option is you have erase , with bb5 erase file by using jaf |
11-16-2009, 16:10 | #25 (permalink) |
Junior Member Join Date: Aug 2009
Member: 1108277 Status: Offline Thanks Meter: 0 | MCU SW : V 06.65 01-04-09 RM-495 (c) Nokia PPM SW : V 06.65 01-04-09 RM-495 (c) Nokia AA Prd.Code: 0577793 Bpr.Code: 0567772 Prod.Sn : IMM669500 HW Vers : 2000 EM VILMA: 16 EM BETTY: 22 RFIC Ver: 064c0601 DSP Vers: ICPR72_09w03 LCD Type: SEIKO IMEI : 359329-02-904493-0 SL Serv : SIMLOCK SERVER SL Conf : 000-00-00000000000 SL Prof : 0141191F00000000 SL Count: 00 00 SL Data Corrupted Provider: Not Found send me solution on [email protected] plz........................plz' |
11-16-2009, 17:08 | #27 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: IN FRONT OF YOU Age: 44
Member: 475440 Status: Offline Sonork: 1604067 Thanks Meter: 965 | Wait Wait Quote:
Wait brother untill sl3 unlocking release ,,,,,,,,,,,,,,,,,,,,,, | |
11-16-2009, 18:22 | #28 (permalink) |
No Life Poster Join Date: Oct 2008 Location: dubai
Member: 884639 Status: Offline Sonork: 100.1597105 Thanks Meter: 266 | *check set info , if all ok *first try to flash with latest version file * if same, reball or replace Avilma, & rtc * after changing Avilma, try to flash with latest version file, * if same, rebuld IMEI , EMC & auto tune (but emc & tune only possible in phoenix sw) set will work 100% |
The Following User Says Thank You to ameerali19 For This Useful Post: |
11-16-2009, 18:56 | #29 (permalink) | |
Freak Poster Join Date: Dec 2008 Location: dubai
Member: 915625 Status: Offline Thanks Meter: 47 | Quote:
check simlocktest, and securityt test. if security fail write pm feild 1 and feild 309 with SX4. u r problem will solve 100% then post u r result | |
Repair nokia 5130 contact service... [ANSWERED & CLOSED] | WeBoXGT | Genie Universal | 5 | 09-17-2010 12:52 |
nokia 5130 contact service | bombayteji | Nokia Hardware & Hardware Repair | 8 | 06-06-2010 13:01 |
Nokia 5130 contact service | nittin_sp | Cyclonebox | 26 | 02-06-2010 21:15 |
nokia 5130 contact service | shammysaini | Universalbox | 1 | 12-15-2009 14:02 |
