Nokia 5130 Display light Problem Hello to all I have lost a track so display light is not working. I try this jumper but still light is not work. http://img202.imageshack.us/img202/511/lightpng1.png Is any one know How to solve this problem ? |
1 Attachment(s) |
1 Attachment(s) |
Bro are u see pic given by me just one track is miss So are you think this jumper is work |
if u already make jumper at pin no 3.....and not work its mean tracks r well .........so u must confirm boosting volt(11v) r producing from light ic at (l2306)......if no.....check light ic +coil+vbat for coil and ic and also confirm pwm300 pulse witch is controlling light driver by switching volt if all ok and 11v r producing from ic ........so remove n2401 and apply that jumper mention by me...........post reply |
Help me pls soon its urgent pls help just tell me about my missing track as you see on the pic. |
what about key board lights? what about boosting volts at l2306? post reply......... |
short both 4.5 pin..... handset will ok. |
Nokia 5130c Lcd Light Solution... 1 Attachment(s) IF You all All are Fail to Solve That Then Do Darect conection of Light's. |
nokia 5130 |
Nokia 5130 display problem Please help me this phone display some time goes off and some time it will automatically comes back |
change the display connector |
I also have same problem but I solved it just connect your minus point with earth It will be solves |
Without ic solution 100% ok http://forum.gsmhosting.com/vbb/f148...00-ok-2005507/ |
thank alot it worked for me |
