Old 06-02-2011, 13:21   #1 (permalink)
Saleemsmj's Avatar
Member: 1122153
Thanks Meter: 443
Nokia 5130 Flashing Ok but not power on..........
Nokia 5130 Flashing Ok but not power on........... allredy try with USb flash in Mx-key but same problem...............
Old 06-02-2011, 13:40   #2 (permalink)
gsmshankarb's Avatar
Member: 1326709
Thanks Meter: 39
1st change 2 keypad ic
Old 06-02-2011, 13:40   #3 (permalink)
biniesh_08's Avatar
Member: 843418
Thanks Meter: 740
br battery connector(bsi)check.............
Old 06-02-2011, 14:02   #4 (permalink)
Saleemsmj's Avatar
Member: 1122153
Thanks Meter: 443
all is ok................... same problem
Old 06-02-2011, 14:05   #5 (permalink)
tejas243404's Avatar
Member: 725038
Sonork: 100.1675584
Thanks Meter: 288
1 ultra sonic chemical washhh
2.half hit to pcb
3.chek new ver, to flash
bat mobile is ok dear
Old 06-02-2011, 15:00   #6 (permalink)
Saleemsmj's Avatar
Member: 1122153
Thanks Meter: 443
2.half hit to pcb
allredy used 7.97 but same problem................. if hardware so please give me right solution for this problem............
The Following User Says Thank You to Saleemsmj For This Useful Post:
Old 06-02-2011, 15:56   #7 (permalink)
Saleemsmj's Avatar
Member: 1122153
Thanks Meter: 443
MXKEY Serial: [FT SCR2000 1] - C08*****
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Driver: UFS2XX, ver: 3.6.0.0, NTMP ver: 2.6.0.0
Module ver: 1.0.0.16978(13-05-2011), Library ver: 1.0.0.10071(13-05-2011)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 04C0010E1A7F465004119052BBE3BE1AF7421BEF
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 00EC 2400 - 0000 8A31 [Samsung ] type: NOR,CMT
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
TransmissionMode: DDR&TX2
Processing MCU file: rm495__07.97.mcusw
[BB5,BB5 ALGORITHM] size: 18.20 MB
Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000
Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK
Erase size: 21 MB
CMT NOR area [00000000-000006BF]
erased in 1 min 4.890 s
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 0C917F11196FDB7378C18EF7260698CA4489DCA0 (RAP Certificate 164 v.1) sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
Programming completed in 11 min 11.922 s
Processing PPM file: rm495__07.97.ppm_mena_a1
[BB5,BB5 ALGORITHM] size: 5.97 MB
Erase size: 8.62 MB
CMT NOR area [01520000-01DBFFFF]
erased in 19.750 s
Programming completed in 3 min 55.046 s
Processing CNT file: rm495__07.97.image_mena_a1_red_128
[BB5,BB5 ALGORITHM] page size: 128 K size: 10.32 MB
UCP page size is 128 K.
Erase size: 34 MB
CMT NOR area [01DC0000-0215FFFF]
erased in 48.828 s
Programming completed in 6 min 15.593 s
Total time for flashing process(boot+erase+write) was 23 min 57.625 s
Phone not responding !
here log........... please tell me how to solve this problem
Old 06-02-2011, 23:03   #8 (permalink)
HBHAVNA's Avatar
Member: 1418631
Sonork: 100.1622972
Thanks Meter: 79
Originally Posted by saleemsmj View Post
mxkey serial: [ft scr2000 1] - c08*****
using device: Ufs_usb v2.8 (c) sarassoft 2007.
Driver: Ufs2xx, ver: 3.6.0.0, ntmp ver: 2.6.0.0
module ver: 1.0.0.16978(13-05-2011), library ver: 1.0.0.10071(13-05-2011)
cmt data :
System asic id: 000000010000022600010006030c192101033000 [rap3g ver: Pa 3.x]
em0 id: 00000296
em1 id: 00000b22
public id: 04c0010e1a7f465004119052bbe3be1af7421bef
asic mode id: 00
root key hash: 9ddbfcfe6e73ced7d8c6268c8eb85723
rom id: 273f6d55dfaaf68f
secondaryboot: Rap3gv3_2nd.fg [bb5] version: 1.30.0 revision: 0.0 size: 0x3c00
supported ids: 0103192101003000, 010c192101003000, 0103192101013000, 010c192101013000, 0103192101003100, 010c192101003100, 0303192101023000, 030c192101023000, 0303192101033000, 030c192101033000, 0103192101001101, 010c192101001101, 0003192101001002, 000c192101001002, 0013192101001002, 001c192101001002
flashid0: 00ec 2400 - 0000 8a31 [samsung ] type: Nor,cmt
extbusc: 0000 0000 0000 0000 0000 0000 0000 0000
transmissionmode: 16bit
algorithm: Rap3gv3_algo.fg [bb5 algorithm] version: 1.40.0 revision: 0.0 size: 0x22c10
supported ids: 0103192101003000, 010c192101003000, 0103192101013000, 010c192101013000, 0103192101003100, 010c192101003100, 0303192101023000, 030c192101023000, 0303192101033000, 030c192101033000, 0003192101002000, 000c192101002000, 0003192101002100, 000c192101002100, 0003192101002200, 000c192101002200, 0003192101012200, 000c192101012200, 0103192101001101, 010c192101001101, 0003192101001002, 000c192101001002, 0013192101001002, 001c192101001002
cmt papubkeys hash: 0c917f11196fdb7378c18ef7260698ca4489dca0
transmissionmode: Ddr&tx2
processing mcu file: Rm495__07.97.mcusw
[bb5,bb5 algorithm] size: 18.20 mb
supported ids: 010c192101013000, 0103192101003000, 0303192101033000, 030c192101033000
storing certificate [npc, variant, r&d, ccc, hwc] ...ok
erase size: 21 mb
cmt nor area [00000000-000006bf]
flash programming ...
Cmt nolo block sent
cmt keys block sent
cmt primapp block sent
cmt pasubtoc block sent
cmt papubkeys: 0c917f11196fdb7378c18ef7260698ca4489dca0 (rap certificate 164 v.1) sent
cmt updapp block sent
cmt dsp0 block sent
cmt mcusw block sent
programming completed in 11 min 11.922 s
processing ppm file: Rm495__07.97.ppm_mena_a1
[bb5,bb5 algorithm] size: 5.97 mb
erase size: 8.62 mb
cmt nor area [01520000-01dbffff]
erased in 19.750 s
processing cnt file: Rm495__07.97.image_mena_a1_red_128
[bb5,bb5 algorithm] page size: 128 k size: 10.32 mb
ucp page size is 128 k.
Erase size: 34 mb
cmt nor area [01dc0000-0215ffff]
erased in 48.828 s
total time for flashing process(boot+erase+write) was 23 min 57.625 s
phone not responding !
Here log........... Please tell me how to solve this problem
try back up rpl data first and full erase with hwk and now try to flash using ufs hwk with latest falsh file 7.97 and restore rpl data than tell me.
Old 06-02-2011, 23:04   #9 (permalink)
HBHAVNA's Avatar
Member: 1418631
Sonork: 100.1622972
Thanks Meter: 79
5130 no start up
cmt data :
em0 id: 00000296
em1 id: 00000b22
asic mode id: 00
erase size: 21 mb
Cmt nolo block sent
cmt keys block sent
cmt dsp0 block sent
erase size: 8.62 mb
erased in 19.750 s
Erase size: 34 mb
erased in 48.828 s
try back up rpl data first and full erase with hwk and now try to flash using ufs hwk with latest falsh file 7.97 and restore rpl data than tell me result bro.
Old 06-02-2011, 23:07   #10 (permalink)
HBHAVNA's Avatar
Member: 1418631
Sonork: 100.1622972
Thanks Meter: 79
5130 flash complate but no power on
cmt data :
em0 id: 00000296
em1 id: 00000b22
asic mode id: 00
erase size: 21 mb
Cmt nolo block sent
cmt keys block sent
cmt dsp0 block sent
erase size: 8.62 mb
erased in 19.750 s
Erase size: 34 mb
erased in 48.828 s
first back up all type data rpl-simlock-pm_rpl etc..., then full erase with ufs hwk and then flash using latest firmware v.7.97 and flash with rj45 cable to using ufs hwk box and now restore rpl data and now your fone is ok bro. If ok tell me result and thanks me.
The Following User Says Thank You to HBHAVNA For This Useful Post:
Old 06-06-2011, 07:19   #11 (permalink)
Member: 1411328
Sonork: Vio-GSM
i have a problem with 5130 no power....
i do chk with HWK Twister
here is LOG
1ST BOOT : C0,07 [] [2.2.0.0]
CMT ASICID: 000000010000022600010006030C192101033000
EM 1 ID : 00000296
EM 2 ID : 00000B22
CMT PUBID : 0B700116F1137E5632FA12277BC0127F2A70CC97
CMT MODE : 00
CMT HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT ROMID : 273F6D55DFAAF68F
CMT 1ST Boot OK
CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1
CMT FLID0 : 00898982-00008A31, Int NU48F512
CMT FLCNT : 00000000000000000000000000000000000000
CMT MCID0 : FFFF0000-00000000
CMT 2ND Boot OK
CMT ALGO : RAP3Gv3_algo_v1331.fg, Ver: 1.33.1
CMT KSIG0 : 0C917F11196FDB7378C18EF7260698CA4489DCA0
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
PASUBTOC : PA_SL3
Rebooting Mobile
no int local mode
no int test mode
flash done ok.....
Old 06-10-2011, 14:27   #12 (permalink)
Member: 725038
Sonork: 100.1675584
Thanks Meter: 288
5130
add me id brotear
[email protected]
Old 07-20-2011, 12:28   #13 (permalink)
Member: 196126
Thanks Meter: 80
Very funny advice pls tell me how to backup rpl from phone in such condition...?
Have same problem flashing ok no local mode its hardware fault I think
Page generated in 0.25175 seconds with 9 queries
