Old 09-13-2013, 12:14   #1 (permalink)
Ali idrees's Avatar
Member: 1851480
Sonork: 100.1660354
Thanks Meter: 142
Arrow Nokia 5130 keypad solution, keys and switches connection
Here's the Nokia 5130 complete keypad solution, this solution shows each certain keypad key connections including the button switches such as the volume up and volume down control buttons and also the MP3 player button switches such as the Start/stop, forward and rewind button switches.
The solution may help repair and fix nokia 5130 keypad malfunction and button switches failure. You may check, trace particular keys which are not able to function by using the repair guide below. Each group of colors indicates that they are connected with each other. So just locate where that particular non working key being connected and mend it found cut or open.
Old 09-13-2013, 12:18   #2 (permalink)
Ali idrees's Avatar
Member: 1851480
Sonork: 100.1660354
Thanks Meter: 142
Arrow Nokia 5130 ON-OFF power key jumper ways
The Power ON/OFF key is isolated and not connected to other group of key connected when the power key fails or or if the line is cut or open.
Old 09-13-2013, 12:20   #3 (permalink)
Ali idrees's Avatar
Member: 1851480
Sonork: 100.1660354
Thanks Meter: 142
Arrow Nokia 5130 keypad filter IC jumper ways
Old 06-30-2015, 07:54   #4 (permalink)
Member: 2419062
nokia 5130 xpressmusic keypad not working
Page generated in 0.11573 seconds with 8 queries
