04-27-2011, 17:29 | #33 (permalink) | |
Junior Member Join Date: Jun 2009
Member: 1048339 Status: Offline Thanks Meter: 6 | Quote:
dude its pm corrupted problem some time first dont flash the phone 1. take rpl back up by mxkey 2. do sx4 by ufs 3. then check the hand set if the handset get on , write rpl without npc data by mxkey 4. write cert with ufs 5 ui setting 6. flash with latest version (7.96 or 7.97) 7. ui again | |
04-28-2011, 12:57 | #35 (permalink) |
Junior Member Join Date: Sep 2010
Member: 1398329 Status: Offline Thanks Meter: 6 | i have 5130 xp when power on just nokia logo than whit scrin i try to flash by mxk but show B V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9169(08-01-2011), 1.0.0.15596(08-01-2011) Processing MCU file: rm495__07.97.mcusw [BB5,BB5 ALGORITHM] size: 18.20 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 2590000BC2C34950E2FF105716604B31688B5B88 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 2400 - 0000 8A31 [Samsung ] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 TransmissionMode: DDR&TX2 Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK Erase size: 21.00 MB CMT NOR area [00000000-000006BF] erased in 0.563 s CMT NOR area [000006C0-0001FFFF] erased in 0.078 s CMT NOR area [00040000-000BFFFF] erased in 1.906 s CMT NOR area [000C0000-0013FFFF] erased in 0.140 s CMT NOR area [00140000-0137FFFF] erased in 58.640 s CMT NOR area [01380000-0151FFFF] erased in 6.297 s Flash programming ... CMT PAPUBKEYS: 0C917F11196FDB7378C18EF7260698CA4489DCA0 (RAP Certificate 164 v.1) written. Programming completed in 11 min 26.985 s Processing PPM file: rm495__07.97.ppm_t [BB5,BB5 ALGORITHM] size: 7.43 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Bootstrap failed! RX Buffer: 0000000000F172 pls help me |
05-02-2011, 10:21 | #36 (permalink) |
Junior Member Join Date: Nov 2010
Member: 1448135 Status: Offline Thanks Meter: 0 | 5130c appear nokia logo a few seconds ant then white blank LCD show. sometimes on till sim network. after a few seconds display dim and LCD is became white. Plz solve the problem. plz also tell me it is software or hardware problem and tell me solution |
05-02-2011, 10:26 | #37 (permalink) |
Member: 1448135 Status: Offline Thanks Meter: 0 | plz help me 5130c when start display is dim till nokia logo or sometimes shows sim network and then display dim and became white LCD shows. Plz complete read and then give me solution. Thanx ur brother |
05-03-2011, 05:08 | #42 (permalink) |
Registered User Join Date: Jan 2010 Location: Tangail,Bangladesh
Member: 1219582 Status: Offline Thanks Meter: 10 | 1--Try with latest version use mxkey & flash with usb 2--Heat cpu by 100w light Table Lamp After 1 hour 1.30 hour check 98% tested Alimul Telecom 98 %%%%%%%%%%%%%%%%%%% ok Try ur Problem Solve |
The Following User Says Thank You to .::ALIMUL::. For This Useful Post: |
06-10-2011, 09:23 | #44 (permalink) |
Junior Member Join Date: Dec 2004 Age: 47
Member: 101838 Status: Offline Sonork: 1612360 Thanks Meter: 6 | [QUOTE=sajidshah50;6531603]1st remove the camera and clean the camera socket then check and post[/QUO thanks problem solved |
The Following User Says Thank You to ByJardel For This Useful Post: |
06-10-2011, 09:58 | #45 (permalink) |
Insane Poster Join Date: Mar 2008 Location: mahesana.guj.india Age: 41
Member: 737752 Status: Offline Sonork: [email protected] Thanks Meter: 8 | nokia 5130c power on but only show nokia logo after phone off InfinityBox BEST flashing but HWK normal mode 99% solution my cell 5130 100% solution ok |
