Old 12-08-2010, 09:00   #1 (permalink)
Dooha_Bd's Avatar
Member: 1427033
Sonork: 100.1596688
Thanks Meter: 1,175
NOKIA 5130c-2690c-2700c Nokia Logo Trun Off Check Solution Step By Step
A1) flash lhe phone higher version via usb or Fbus
2) usb flashing time computer show usb error?
must check usb connector usb controll
driver(remove usb esd)
usb flashing and fbus flash 100% done?but phone same nokia logo then trun off?
B1) open handset then check display connector or change display(display also make this problem)
2) remove camera and power on phone with battery,phone still same problem(nokialogo then trun off
3) check vcore,vio,vdram vrfc volt
this 4 volt controlled by combo ic
vdram,vrfc,vio volt controlled by AVILMA
Vcore controlled by BETTY
this 4 volt is prefect???then one thing is conformed avilma betty working fine
4) reflow or change keypad ic
5) Remove MMC ic
6) BT ic also make this problem(6120 75% nokia trun off bt ic)
7) finaly reflow or change combo ic
Respected viewers if you have any openion please post here its healpfull to all.
The Following 48 Users Say Thank You to Dooha_Bd For This Useful Post:
Old 12-08-2010, 09:19   #2 (permalink)
rashel.com's Avatar
Member: 460857
Thanks Meter: 780
This is not a perfect Solution......................
where is the solution????????????????????????????????
The Following 2 Users Say Thank You to rashel.com For This Useful Post:
Old 12-08-2010, 09:31   #3 (permalink)
Wingstel's Avatar
Member: 1077758
Sonork: 100.1619202
Thanks Meter: 433
Plz One Perfecty Soluatoin
Accept Gsm Member This Post
The Following User Says Thank You to Wingstel For This Useful Post:
Old 12-08-2010, 09:34   #4 (permalink)
Member: 328688
Thanks Meter: 1,572
this not perfect Solution's............
The Following User Says Thank You to CHAUDHRAY ARSHAD For This Useful Post:
Old 12-08-2010, 09:43   #5 (permalink)
shakeel145's Avatar
Member: 510445
Sonork: 100.1638301
Thanks Meter: 351
give us perfect Solution's............
Old 12-08-2010, 09:43   #6 (permalink)
MMDEBILI's Avatar
Member: 360073
Thanks Meter: 2,180
buffffffffffffffffffffffffffffffffffffffffffffffff ffffffffffffffffff
Old 12-08-2010, 09:56   #7 (permalink)
Dooha_Bd's Avatar
Member: 1427033
Sonork: 100.1596688
Thanks Meter: 1,175
Thanks for reply bro,you should look or read this post welly,what i wants to say?if its not perfect probid me what should i do ?.
Old 12-08-2010, 11:13   #8 (permalink)
rahulk99k's Avatar
Member: 485686
Thanks Meter: 539
steal from another thread? don't make spam......this post is s copy of shijilfonotly, see this (come to discussion)Very Strange Problem With 5130(Nokia Logo Then Trun Off)
Originally Posted by SHIJILFONOTLY View Post
A1)flash lhe phone higher version via usb or Fbus
2)usb flashing time computer show usb error?
must check usb connector usb controll driver(remove usb esd)
B1)open handset then check display connector or change display(display also make this problem)
2)remove camera and power on phone with battery,phone still same problem(nokialogo then trun off)???
3)check vcore,vio,vdram vrfc volt
4)reflow or change keypad ic
5)Remove MMC ic
6)BT ic also make this problem(6120 75% nokia trun off bt ic)
7)finaly reflow or change combo ic
no more option like this cause
thank u for very nice to runing this discussion
special thanks go to ktkwajid,neilthirumuttam
Old 12-08-2010, 11:40   #9 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
i just can say 5130.2730.2700,2690 its flash ic problem(double layer ic)
so only rehot the flash ic solve it...
i have done more than 5/6 pcs....
Old 12-09-2010, 14:19   #10 (permalink)
madhavunlockr's Avatar
Member: 533476
Thanks Meter: 1,855
perfect iam use fuul oooooooooooooooooooooooooooooooooook sir
The Following User Says Thank You to madhavunlockr For This Useful Post:
Old 12-10-2010, 06:17   #11 (permalink)
Member: 533476
Thanks Meter: 1,855
Originally Posted by dooha_bd View Post
nokia 5130c-2690c-2700c nokia logo trun off check solution step by step
a1) flash lhe phone higher version via usb or fbus
Must check usb connector usb controll
vdram,vrfc,vio volt controlled by avilma
vcore controlled by betty
5) remove mmc ic
6) bt ic also make this problem(6120 75% nokia trun off bt ic)
respected viewers if you have any openion please post here its healpfull to all.
[good post good post
The Following 8 Users Say Thank You to madhavunlockr For This Useful Post:
Old 12-10-2010, 09:12   #12 (permalink)
Member: 759885
Thanks Meter: 3
good share .....thanks
Old 12-10-2010, 09:22   #13 (permalink)
Member: 715158
Thanks Meter: 4
hi
n95 jcmncgbm gbkghkgfc
Old 12-10-2010, 10:21   #14 (permalink)
waqarN70's Avatar
Member: 583454
Thanks Meter: 80
1.flash via dead usb if not done
2.check camera module if still no luck
3.change bt ic
works for me each time
Old 12-10-2010, 11:13   #15 (permalink)
ARIF GIGANI's Avatar
Member: 890965
Sonork: 100.1605360
Thanks Meter: 180
Nokia Logo Trun Off ??????
fast chek the softwar info & aaftar work in all hardwar do u undarstend brathar
Seeking for flash nokia 5110 old version (3 version) can exchange for new Tomas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 10-14-2017 20:29
Page generated in 0.47840 seconds with 8 queries
