Old 08-01-2013, 13:11   #1 (permalink)
Member: 14857
Thanks Meter: 4
Nokia C2-05 no power Please Help
Nokia c2-05 Dropped on the floor does not power on any more I've folowed power switch ways solution no use
The Phone draws about 20 ma on 4.1V on the power supply but the current stays as it and the phone not powered please help
Old 08-01-2013, 13:17   #2 (permalink)
raisalina's Avatar
Member: 1911970
Sonork: 9741081772
Thanks Meter: 2,075
Nokia C2-05 power switch way
http://forum.gsmhosting.com/vbb/f148...tions-1690951/
salina rai 9741081772
Old 08-01-2013, 13:18   #3 (permalink)
Member: 14857
Thanks Meter: 4
I've tried that still dead
Old 08-02-2013, 07:47   #4 (permalink)
d-Artigo's Avatar
Member: 1573913
Sonork: hardware illustration
Thanks Meter: 7,628
nokia c2-05 crashed into the floor
try unloading its handset pcb remove it from the casing
see which components or broken shift
when consumption 20 mAh handset certainly short-circuited
1.coba injectable use handset with a voltage of 1 volt psu to 3.7 v and touch where the hot component
if not that hot ... try rehot its handsets with low temperature
2.handset die from falls possibility ic power ic and pa but if
see consumption above the analysis is faulty software .. Will do his version of the program and the type of the current version up grade
Page generated in 0.13808 seconds with 8 queries
