Old 04-06-2008, 20:51   #1 (permalink)
GOODNESS's Avatar
Member: 89584
Thanks Meter: 68
E51 mic solution needed
please i need solution for e51 mic.it seems is same mic with 5310,e90,etc.
The Following 7 Users Say Thank You to GOODNESS For This Useful Post:
Old 06-29-2008, 18:39   #2 (permalink)
Member: 758550
Thanks Meter: 15
ry use this solution, MIC use VSIM2 1.8V, if 1.8V on C2220 is disapeared - connect with C2215 VIO_V 1.8V (not used in phone work)
sorry, can't upload an image - shall try tommorow
The Following 8 Users Say Thank You to brak0del For This Useful Post:
Old 06-29-2008, 18:59   #3 (permalink)
Member: 515130
Thanks Meter: 304
try this solution
br
shahzad
The Following 24 Users Say Thank You to shahzad-0004 For This Useful Post:
Old 06-29-2008, 19:45   #4 (permalink)
GOODNESS's Avatar
Member: 89584
Thanks Meter: 68
i think the mic is faulty,cos sometimes mic work for some minutes and sometimes is bad
The Following 2 Users Say Thank You to GOODNESS For This Useful Post:
Old 06-30-2008, 16:27   #5 (permalink)
Member: 758550
Thanks Meter: 15
http://www.qciklas.lt/solution/E51_m...by_brk0del.jpg
The Following 4 Users Say Thank You to brak0del For This Useful Post:
Old 07-24-2008, 03:54   #6 (permalink)
Member: 713325
Thanks Meter: 3
the sollution came dear just change mic only i sucessfully do for 200 phones
The Following 3 Users Say Thank You to CRIME FILE For This Useful Post:
Old 10-01-2008, 19:44   #7 (permalink)
Member: 124069
Thanks Meter: 59
the sollution came dear just change mic only 100% ok.......................
The Following 10 Users Say Thank You to aftab70 For This Useful Post:
Old 10-30-2008, 15:31   #8 (permalink)
Member: 215651
Thanks Meter: 7
ya thats wright.............
The Following 2 Users Say Thank You to nazeem For This Useful Post:
Old 10-30-2008, 17:33   #9 (permalink)
shahidsattar's Avatar
Member: 388454
Thanks Meter: 1,101
change the mic thn check the tracks tahn change or jumper mic ic
The Following User Says Thank You to shahidsattar For This Useful Post:
Old 10-30-2008, 18:07   #10 (permalink)
Member: 883349
hello im new in this forum.i try to change but result same problem.maybe this problem line.tnx
The Following User Says Thank You to Randy A. Datuon For This Useful Post:
Old 11-23-2008, 14:07   #11 (permalink)
microera's Avatar
Member: 4923
Thanks Meter: 74
maybe some info how to change MIC in E51, because of overheating area?!
On another site of phone are many elements......
any hint?
The Following User Says Thank You to microera For This Useful Post:
Old 12-18-2008, 17:26   #12 (permalink)
Member: 927140
Thanks Meter: 2
Asalam Alaikum
Sir agr 8/10 mic change kerien to 1/2 mic theek nikal hi ayega
The Following User Says Thank You to gsmpakistan For This Useful Post:
Old 12-18-2008, 17:29   #13 (permalink)
Member: 927140
Thanks Meter: 2
hello sir,
If u change 8 or 10 E51 good quality mic then atleast 2 should be work correctly.We know that because we do same type of practical
Thnx
Old 12-18-2008, 17:31   #14 (permalink)
Member: 927140
Thanks Meter: 2
good joke dear.Check the ******istan
Old 02-07-2009, 19:43   #15 (permalink)
microera's Avatar
Member: 4923
Thanks Meter: 74
I search forum but no one can explain more detailed how to change mic on E51
1st problem .... remove old not working mic
2nd problem .... change new mic
any detailed info or maybe video how to change microphone on E51, because rehoting this digital mic is big problem?
The Following 3 Users Say Thank You to microera For This Useful Post:
E51 Mic Solution 1000% OK .......By cTs cts2007 Nokia Hardware & Hardware Repair 36 11-03-2010 09:06
..::6680 mic solution needed urgent::.. HUM Nokia Hardware & Hardware Repair 4 09-30-2010 10:26
e51 backlight solution needed adaki_vishal Nokia Hardware & Hardware Repair 3 07-27-2010 13:57
Nokia E51 charging solution needed Unicom Nokia Hardware & Hardware Repair 1 03-09-2010 07:50
E51 Mic Solution 1000% OK .......By cTs cts2007 Nokia Base Band 5 ( BB-5 ) 2 10-06-2009 21:12
Page generated in 0.22109 seconds with 10 queries
