01-19-2004, 19:54 | #1 (permalink) |
Freak Poster Join Date: May 2002 Location: none Age: 49
Member: 11926 Status: Offline Thanks Meter: 0 | nokia 5210 black display I already changed hagar, cobba and CCOnt and stilss the same. Any help is appreciated. Thks |
01-27-2004, 23:38 | #7 (permalink) |
No Life Poster Join Date: Dec 2001 Location: United Arab Emirates, Dubai Age: 52
Member: 7751 Status: Offline Thanks Meter: 74 | @All As many knows these problems occur mainly in 5210. Because both CPU (MAD if you will) and Flash ic is unglued for some reason. Well to the faults. 1 : For black screen it's mostly CPU, reflow or change it. Sometimes only it has to do with the flash. So before doing anything be sure on the fault. 2 : If Flash ic is damaged or some balls oxidized due to humidity, then phone behaves strange i.e. when bottoms are pressed the phone powers off, but finds network and starts up normally, only in few cases thse problems can be cured by flashing. So only solution is as MrHazeem says, reball/change flash ic. Regards |
Nokia 1600 Blank display with black colour. | akter_81 | Nokia Hardware & Hardware Repair | 10 | 09-23-2011 11:27 |
Nokia N73 Black display | bezano1 | Universalbox | 10 | 12-23-2009 11:10 |
6085 BIG lcd show NOKIA then black DISPLAY | hooi76 | Nokia Hardware & Hardware Repair | 4 | 01-11-2009 00:11 |
Nokia 6300 Black Display | rishu | Nokia Hardware & Hardware Repair | 3 | 10-25-2008 04:49 |
nokia 6280 black display | kamal07 | Nokia Hardware & Hardware Repair | 5 | 05-07-2008 17:22 |
