Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Junior Member Join Date: Aug 2005 Age: 42
Member: 166650 Status: Offline Thanks Meter: 14 | ![]() you need to re-heat or replace flash IC, make sure you put alot of flux under and around the IC and re-heat and then gently tap the IC sideways. Software hardly ever works with this problem so I changed Flash IC and all the phones were repaired 100%. Flash IC is located next to sim pads above vibrator pads. Good Luck |
![]() | #5 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: May 2005 Location: Baguio City, Benguet
Member: 149576 Status: Offline Thanks Meter: 56 | Quote:
Nokia 5210 All Reapiring Solutions | GsmUniversal | Nokia Hardware & Hardware Repair | 6 | 04-10-2009 23:31 |
Nokia 5210 solution by sureshplaza | sureshplaza | Nokia Hardware & Hardware Repair | 0 | 03-31-2009 13:57 |
Nokia 5210 Solution by milan dhal | bunty2008 | Nokia Hardware & Hardware Repair | 0 | 03-29-2009 12:11 |
Nokia 5210 freezing | Xanga | Nokia Hardware & Hardware Repair | 6 | 09-18-2003 00:17 |
