12-02-2009, 20:47 | #3 (permalink) |
Freak Poster Join Date: Apr 2007 Location: Around The World
Member: 482670 Status: Offline Thanks Meter: 125 | brother every nokia sim ic is solution same.. just remember that point. 1) every sim ic got 8pin rite? u just nid to remember whict side is less 1 pin( this less pin must be on left side) then start it jumper <--> then 2nd line n 3rd line just jumper it 1st pin to 3rd pin .. like the example picture.. next time u will never nid to find sim ic jumper anymore.. did u understand now?? just remember that less pin there must be on << left side then u start jump it like pic.. ucan see all picture all sim ic is oso same on nokia.. eventough is new nokia set oso can jumo like this..good luck |
12-02-2009, 22:30 | #4 (permalink) |
Freak Poster Join Date: Oct 2009
Member: 1150643 Status: Offline Thanks Meter: 40 | check SIM connector , check EMIF SIM check PA. check VSIM on the SIM connector if the on-off button voltage of 1.8 V and at normal voltage 3V. if there is no voltage or less UEM problem. |
6030 insert sim i try chang ic then remove and make jumper but same insert sim | shani72 | Nokia Hardware & Hardware Repair | 7 | 01-20-2010 06:06 |
6610i insert sim i try all jumper and track but same insert sim | shani72 | Nokia Hardware & Hardware Repair | 1 | 09-07-2009 08:02 |
insert sim chip with phone se k550im insert sim | lyne | Old Ericsson Phones & Sony Phones | 0 | 03-16-2009 08:50 |
Nokia 3120 dual sim : sim card rejected or insert sim card msg??? | adrian17w | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 10-30-2005 18:25 |
3210 - "Insert SIM", but SIM is inserted !?! | MaRiN | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-29-2000 17:08 |
