Nokia 5233 memory card corrupted hi friends.today i got nokia 5233 in memory card problem i try to change his m.m.c ic.but its show memory card corrupted any new sol |
[IMG]http://2.bp.********.com/-RSWBvKxr0Ww/TgiowLHrNFI/AAAAAAAAAZA/HDnv7NYO90A/s400/Nokia+5230+mmc+solution..jpg[/IMG] |
i change it any another sol? |
1 Attachment(s) Quote:
Replace mmc socket post result http://img543.imageshack.us/img543/7585/alokgsm1.png |
replesh memory card ic glash not black Quote:
5233 memory card crupted Quote:
FIRST Change with another MMC at first SECOND Check Vbat 3.7 VOLT at C3207 Check vio 1.8 VOLT at C3200 Without both voltage ABOVE the MMC will not detected/maybe corrupted. even you change the driver (N3200) 10 times your problem will not solved at last, If both voltage is exist, you can change N3200 if one of both voltage is missing or corrupt then you need to make jumper from the same voltage |
good job thanksssssssssssssssssssss |
There is no solution to repair corrupted MMC card. You have to replace with the new one. However, if you have data like music, photos, videos etc then you can recover from the damaged card with the help of recovery software. To know how to recover see http://memorycardrecovery.biz |
thxxxxxxxxxxxxxxxx sir |
i think mmc socket problem.................... |
any more solution for memory card corrupted |
