nokia 5233 memory full nokia 5233 shows memory full delete some data flashed with high version but problem not solved help me please |
flash cnt file only it will be fine |
its software problem i have solved alot of cases in this error via flashing |
do these steps 1.factory reset 2.format its c drive. and after these flash your phone. Your problem will solve. Br, ..::ALI::.. |
nokia 5233 memory full 1 Attachment(s) |
5333 camara open memory full indication 5233 flashed with latest version but still same complaint. |
5233 memory full while open camara 5233 memory full while open camara. flashed with latest version but still same complaint |
then factory settings then check.. |
if u have a HTI try to download d original version with d updated version.....type d product code and download to support site....... |
HTI is the best sulotion bro......go to service,phonetest and tap run all u can see what is d error.....i think its pm files i always encouter the same problem.....always write pm or CNT files.problem solve.....if isn't solve try to hardware procedure.......... |
use hti dongle and download the product code of th fone in hti support.....................it make your problem solve.......and format after reflash the fone............. |
Back up 2file 1). - RPL file 2). - full pm file Then replace flash chip 3) - and flash with ay version 4). Afther flah set on imel 12345 5) Write rpl 6). Afher imei ok but. Sim lock data not read 4) afther write pm 👍👍👍👍👍💥💥💥💥💥💥💥😊😊😊 1000%ok brother try this Sent from my iPhone using ******** - now Free |
