Old 11-16-2011, 11:42   #1 (permalink)
Member: 753490
Thanks Meter: 14
Lightbulb nokia 5233 memory full
nokia 5233 shows memory full delete some data
flashed with high version but problem not solved
help me please
The Following User Says Thank You to rituritu For This Useful Post:
Old 11-16-2011, 12:01   #2 (permalink)
Member: 1420780
Thanks Meter: 3
flash cnt file only it will be fine
Old 11-16-2011, 12:30   #3 (permalink)
Member: 1680941
Sonork: +91-7567507692
Thanks Meter: 21
Thumbs down
help me please
flash your set with mx key and must note that flash file version greater then your set own flash version. Otherwise set going to dead. Cant flash with hwk because your set going to dead.
The Following User Says Thank You to ahir1790 For This Useful Post:
Old 11-16-2011, 13:03   #4 (permalink)
unlock phones's Avatar
Member: 1552610
Sonork: 100.1604734
Thanks Meter: 1,370
its software problem i have solved alot of cases in this error via flashing
Old 11-16-2011, 13:22   #5 (permalink)
Member: 1679236
Sonork: Prohibited
Thanks Meter: 45
do these steps
1.factory reset
2.format its c drive.
and after these flash your phone.
Your problem will solve.
Br,
..::ALI::..
Old 11-16-2011, 14:25   #6 (permalink)
Member: 753490
Thanks Meter: 14
problem solvedh big thsnkes
Old 11-16-2012, 11:35   #7 (permalink)
Member: 1557028
5333 camara open memory full indication
5233 flashed with latest version but still same complaint.
Old 11-16-2012, 11:37   #8 (permalink)
Member: 1557028
5233 memory full while open camara
5233 memory full while open camara.
Old 11-17-2012, 01:34   #9 (permalink)
ren_mglab's Avatar
Member: 1501033
Thanks Meter: 35
sir check camera settings then if not work flash cnt then check
then factory settings then check..
The Following User Says Thank You to ren_mglab For This Useful Post:
Old 11-17-2012, 02:00   #10 (permalink)
Member: 1840152
if u have a HTI try to download d original version with d updated version.....type d product code and download to support site.......
Old 11-17-2012, 02:08   #11 (permalink)
Member: 1840152
HTI is the best sulotion bro......go to service,phonetest and tap run all u can see what is d error.....i think its pm files i always encouter the same problem.....always write pm or CNT files.problem solve.....if isn't solve try to hardware procedure..........
Old 12-04-2012, 10:45   #12 (permalink)
Member: 1840152
use hti dongle and download the product code of th fone in hti support.....................it make your problem solve.......and format after reflash the fone.............
Old 10-15-2013, 07:50   #13 (permalink)
Member: 1642979
Sonork: 100.1613407
Thanks Meter: 183
help me please
i have same problem help
Old 10-25-2013, 04:00   #14 (permalink)
sreeju007's Avatar
Member: 1490333
Sonork: 100.1646411
Thanks Meter: 38
Back up 2file
1). - RPL file
2). - full pm file
Then replace flash chip
3) - and flash with ay version
4). Afther flah set on imel 12345
5) Write rpl
6). Afher imei ok but. Sim lock data not read
4) afther write pm
1000%ok brother try this
Sent from my iPhone using ******** - now Free
Old 07-08-2014, 18:41   #15 (permalink)
Member: 1963898
Thanks Meter: 52
Originally Posted by ..::ALI::.. View Post
do these steps
1.factory reset
Br,
..::ALI::..
bro,,,,,still same problem.....what can i do ......flashed with ATF but sameeeee problem
Page generated in 0.21904 seconds with 10 queries
