06-09-2007, 14:28 | #3 (permalink) |
Junior Member Join Date: Jun 2003 Location: greece Age: 66
Member: 32940 Status: Offline Thanks Meter: 7 | 5200-5300 Mic Solution For Nokia 5200-5300 If Mic Doesn't Work, If You Change The Mic And No Result Then Unsolder The Small Glass Filter And Make A Jumber With A Resistor 1 KΩ According To The Schematic Below. It Works 100% |
The Following 3 Users Say Thank You to sidnis For This Useful Post: |
06-11-2007, 07:50 | #5 (permalink) |
Member: 32940 Status: Offline Thanks Meter: 7 | explanation what do you mean when you said that you can't see anything? the schematic is written in a word file do you have installed Microsoft office in your computer? because i check it today and i can see it |
06-11-2007, 11:13 | #7 (permalink) |
Member: 32940 Status: Offline Thanks Meter: 7 | mic solution The solution is checked and works .Usualy if phone is water damaged then the esd glass filter 2100 is faulty and no mic.Check diagram and is clear what you have to do.Unfortunatly i have no pdf editor and the schematic is made by me in a simple WORD file Last edited by sidnis; 06-13-2007 at 07:23. |
08-06-2007, 21:48 | #12 (permalink) |
Member: 32940 Status: Offline Thanks Meter: 7 | mic ic Check the picture with open eyes and you will find left the board with mic ic and to the right the mic ic magnified.Just unsolder the mic ic and make the modification .Works 100% |
08-09-2007, 17:41 | #13 (permalink) |
Member: 32940 Status: Offline Thanks Meter: 7 | Mic 5200-n70 The solution I gave you above for the mic for 5200 also it works for NOKIA N70 and NOKIA N72 |
The Following User Says Thank You to sidnis For This Useful Post: |
nokia 5300 no light on keypad and lcd | taufiks mobile | Nokia Hardware & Hardware Repair | 4 | 03-02-2011 11:48 |
nokia 5300 no provider or contact service | Vilkacis | HWK | 4 | 12-12-2009 17:21 |
nokia 5300 no key pad help | unlock_solution | Nokia Hardware & Hardware Repair | 5 | 10-06-2008 19:04 |
nokia 5300 no light | romeo_1 | Nokia Hardware & Hardware Repair | 0 | 09-23-2007 09:15 |
Nokia 5300 No Light | neo_49 | Nokia Hardware & Hardware Repair | 2 | 08-10-2007 10:02 |
