01-08-2008, 07:58 | #1 (permalink) |
Freak Poster Join Date: Sep 2006 Location: "" I N D I A ""
Member: 349089 Status: Offline Thanks Meter: 112 | nokia 5310 mic problem Any bdy have 5310 mic not working solution i dont have original mic to change.any idea to replace with another mic is welcome any help pls. A TO Z |
The Following 8 Users Say Thank You to DEEPAK_ATOZ For This Useful Post: |
01-17-2008, 08:29 | #2 (permalink) |
Junior Member Join Date: Apr 2007
Member: 489183 Status: Offline Thanks Meter: 5 | mic you would be change mic brother when you will apply mic then you heat only around mic slow. your mic would be succesfully work. before apply mic you check mic tips tips is working possition then you change mic.ok |
The Following 5 Users Say Thank You to jerilink For This Useful Post: |
01-17-2008, 08:58 | #3 (permalink) |
No Life Poster Join Date: Jan 2007 Location: agrabad,ctg,Bangladesh Age: 41
Member: 426688 Status: Offline Sonork: 100.1596204 Thanks Meter: 524 | bro, check your mic without tips if not ok then change if ok then make jumper if your problem does not solved post again reply |
The Following 3 Users Say Thank You to jimm07ct For This Useful Post: |
03-14-2008, 14:41 | #5 (permalink) |
Junior Member Join Date: Apr 2004 Age: 47
Member: 61318 Status: Offline Thanks Meter: 8 | Replace with other new Nokia models, like 6500, 5610, 8600, but only this model, because this mic is digital, and replace with other diferent- that`s impossible |
The Following 2 Users Say Thank You to Skrew For This Useful Post: |
03-22-2008, 14:41 | #6 (permalink) |
Member: 349089 Status: Offline Thanks Meter: 112 | problem solved only with changing the mic with the same MIC BUT new one A TO Z |
The Following User Says Thank You to DEEPAK_ATOZ For This Useful Post: |
04-22-2008, 15:01 | #8 (permalink) |
Freak Poster Join Date: Nov 2006 Location: MARS, Mirashee
Member: 392116 Status: Offline Thanks Meter: 18 | hi all members my 5310 mic sound not suficient, how can solve it thanks chandan |
The Following 2 Users Say Thank You to Deb Chandan For This Useful Post: |
04-22-2008, 15:29 | #10 (permalink) |
Junior Member Join Date: Apr 2008
Member: 756419 Status: Offline Sonork: 23401 Thanks Meter: 5 | can anybody solve this problems for me pls w700i SE pls when inserted memory card it reboot alway what can the solution be pls waiting for your reply bye |
The Following User Says Thank You to DARREN4LUV For This Useful Post: |
5310 Mic problem | noufalrv | Nokia Hardware & Hardware Repair | 30 | 11-20-2010 10:47 |
Nokia 5310 Mic direction solution 100% | gul551 | Nokia Hardware & Hardware Repair | 19 | 08-10-2010 14:05 |
Nokia 5310 mic solution 100%%%%%% | gul551 | Nokia Hardware & Hardware Repair | 6 | 07-06-2010 21:59 |
5310 mic problem . changed mic 5 times | TRABEL | Nokia Hardware & Hardware Repair | 4 | 06-17-2009 13:33 |
5310 mic problem | maheshsaiganesh | Nokia Hardware & Hardware Repair | 8 | 12-14-2008 19:38 |
